Old 04-16-2014, 11:25 PM   #1
1963chevyc20
1963chevyc20's Avatar
Question about transmition
Oa 3 speed manual do I have to have an adapter for a 3 on the tree or will it hook up just fine?
1963chevyc20 is offline   Reply With Quote
Old 04-17-2014, 06:46 AM   #2
PGSigns
PGSigns's Avatar
Re: Question about transmition
What is in it now?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-17-2014, 09:25 AM   #3
1963chevyc20
I am looking at purchasing a tranny. It is a floor shifter. Can I just remove the shifter on it and hook up my callom shifter. Will it work or do I have to adapt it?
Old 04-17-2014, 09:27 AM   #4
1963c-10
1963c-10's Avatar
You will need the shift rods that connect from the column to the transmission. The factory standard trans was the mc318 Muncie 3 speed, non-synchro 1st gear.
I may have an extra set of shift rods....I can look when I get home if you don't have them.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-17-2014, 09:34 AM   #5
1963chevyc20
Thanks a million but I have them! But it really helps out. Do all I do is just hook them up like the old one I had?
Old 04-17-2014, 11:49 AM   #6
66Submarine
66Submarine's Avatar
Yes
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 04-17-2014, 11:50 AM   #7
1963c-10
1963c-10's Avatar
Correct. place the trans in neutral and hook up the rods. Wouldn't hurt to replace whatever shift linkage bushings you can while they are off.
Old 04-17-2014, 12:54 PM   #8
1963chevyc20
Sounds good. Thanks everyone!
Old 04-17-2014, 12:55 PM   #9
1963chevyc20
If you read my old thread what the heck was that you will see why I need a new tranny
Old 04-17-2014, 05:00 PM   #10
Wrenchbender Ret
You will probably need the levers also. Most floor shifters come with there own levers.
Wrenchbender Ret is offline   Reply With Quote
Old 04-17-2014, 08:51 PM   #11
1963chevyc20
Sounds good.
Old 04-17-2014, 09:03 PM   #12
1963c-10
1963c-10's Avatar
Yeah, i saw you had some problems with it. Hopefully the swap will go smoothly for you!
Old 04-17-2014, 11:45 PM   #13
1963chevyc20
Thanks! So do I!
Old 04-18-2014, 09:08 AM   #14
dashaund
Edited by Forum Staff
You'll need to use the classified area of the forum.
dashaund is offline   Reply With Quote
Old 04-18-2014, 11:29 AM   #15
1963chevyc20
Well inwet to pull my old tranny out today. Unhooked it from the shift levers, the speedometer cable, and when I went to un hook it from the bell housing it won't come off? The bolts turn for ever but won't come out? What's up! I have had alot of issues with this truck every time I work on it it never goes smooth! What gives?
Old 04-18-2014, 11:30 AM   #16
1963chevyc20
Oh and I already did the drive shaft also.
Old 04-19-2014, 02:01 PM   #17
Ronw435
Ronw435's Avatar
You will have to remove the inspection pan on the bottom and then you can access the bottom two trans bolts. Why they ever did it like this is beyond me. I have a 65C-10 with a manual 3spd. and the bottom two have the bolt put in from the flywheel side. With the inspection pan removed you should be able to see the head of the bolts. The top bolts should screw into the bell housing and don't have nuts on them. The bottom two have nuts and washers on them.
Ronw435
Ronw435 is offline   Reply With Quote
Old 04-19-2014, 02:02 PM   #18
Ronw435
Ronw435's Avatar
Sorry, the inspection pan it on the bell housing.
Old 04-19-2014, 02:03 PM   #19
Ronw435
Ronw435's Avatar
Does anyone know if you can put a syncro ring on first gear on the manual three speeds? The number on my is G 28
