Old 04-17-2014, 10:36 AM   #1
bluechevy66
front suspension upgrade?
Have any of you upgraded your front suspension on a 60 to 66 with a front end from a 73-87 and up to 91 suburban with disc brakes? I've heard it's almost a bolt on change with only a couple of holes to drill. Any help would be appreciated
bluechevy66 is offline   Reply With Quote
Old 04-17-2014, 10:46 AM   #2
63burban
Chevy addict
Re: front suspension upgrade?
That's exactly what it is, pretty much a direct fit plus a few holes. Gotta love GM !!
63burban is offline   Reply With Quote
Old 04-17-2014, 10:59 AM   #3
60-66
60-66's Avatar
Night and day difference in turning and stopping. Currently doing it again on this 63.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-17-2014, 11:00 AM   #4
siggyfreud
siggyfreud's Avatar
Yep. I just did this a bit ago. Two new holes to drill, two holes to "expand". Once you get the crossmember in place, line it up with holes going straight down through the frame, and then as many of the horizontal holes as possible. It'll become clear quickly quick holes need to be drilled new, and which ones need to be elongated. It's the same on both sides.
siggyfreud is offline   Reply With Quote
Old 04-17-2014, 12:30 PM   #5
PGSigns
PGSigns's Avatar
I have don the 65 and have the parts to do the 66. On the 65 I did not swap the cross member just everything else. On the 66 will swap it all.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-17-2014, 01:41 PM   #6
bluechevy66
Very nice.... so is it just holes for the crossmember in the frame?
Old 04-17-2014, 03:25 PM   #7
siggyfreud
siggyfreud's Avatar
If you're bringing everything over from the donor then yes it should just be holes in the crossmember.
Old 04-17-2014, 04:40 PM   #8
forestb
forestb's Avatar
If you have a 66 why bother? If you are looking for disks I have heard a lot of talk about using everything but the cross member on the truck from a later model truck with disks. I replaced mine and I am still wondering why.
forestb is offline   Reply With Quote
Old 04-17-2014, 04:46 PM   #9
familyfast64
familyfast64's Avatar
I agree, I don't see much of a benefit unless you have the torsion bar suspension set up. Disc brakes will do the trick. Unless of coarse yours is just in bad shape or something then hey, Idk. There could be a lot of good reasons, nevermind my post. Keep at it, there's nothing wrong with that.
Live and let live
familyfast64 is offline   Reply With Quote
Old 04-17-2014, 08:04 PM   #10
encasedmetal
what steering shaft is that you're using for the power steering?
encasedmetal is offline   Reply With Quote
Old 04-17-2014, 08:36 PM   #11
60-66
60-66's Avatar
All of the steering linkage, crossmember, etc is all 1983 Chevy 1/2 ton. This way I'm not mixing and matching parts. Had to mount the newer style idler arm to make it all work but that's simple. This is the third time I've done it this way, it just gets easier. But I agree you really don't need to go this far .
Old 04-17-2014, 08:36 PM   #12
jtrichard
do you have any pics of the mounting of the power steering gear? how you cut the frame? ect.
jtrichard is offline   Reply With Quote
Old 04-17-2014, 08:42 PM   #13
encasedmetal
cool. I've got all 1980 front susp and power steering but didn't grab the steering shaft. my bad
Old 04-17-2014, 09:47 PM   #14
60-66
60-66's Avatar
Sorry I didn't think to do that . Honestly one of Captain Fabs brackets would do the job so no cutting is needed. This is a frame I started on three years ago and was experimenting . I would not mount or cut the frame exactly like this the next time. My only reason for doing this was to keep the steering box closer to the frame rail like factory.
Old 04-17-2014, 09:51 PM   #15
60-66
60-66's Avatar
Now that I've re read this, by steering shaft did you mean the one from steering wheel/ column down to the steering box ? That's just a shortened stock shaft cut and re welded.
Old 04-18-2014, 08:00 AM   #16
encasedmetal
I think you are referring to my question- and yes that's what I meant. thanks for the info
Old 04-18-2014, 09:06 AM   #17
bluechevy66
I don't necessarily need the crossmember, just thought it might be easier to slide it all in as a unit instead of unbolting each piece. But, that's why I'm here asking questions... because while I have the skill to do all of this stuff, I don't have the knowlege yet.
You guys on here are WAY better than childers manuals or Google. In fact, when I first started looking for answers about my 66, every Google search pointed me here.
You dont know how much I appreciate all yous guys help!
Old 04-18-2014, 10:24 AM   #18
siggyfreud
siggyfreud's Avatar
I personally think dropping the entire member in is easier, unless you plan to replace all the components anyways. For me going from a C20 to C10 I think the full swap was the easiest route though.
Old 04-18-2014, 12:11 PM   #19
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done it both ways a good number of times. For me, it boils down to this.
If the engine is in place, I swap the newer parts to the existing crossmember. If the engine is out, I swap the crossmember and all.
Getting those lower control arm u bolts off with the engine in place sucks bad. No way to get the heavy guns in there and bang them off so you're forced to use a ratchet and wear yourself out cranking them off.
