Old 07-28-2003, 10:48 PM   #1
backinblack
Question Turn Signal Cam
I am trying to change the turn signal cam in my 69 Chev, and cannot seem to figure out how the old one comes out! I have already popped out the two little metal connectors on the right side, and dont know how the thinnest one goes back in, but anyway, can't seem to get it out, and the direction for the new one sucKs! Please HELP!
Anyone with pictures also appreciated.
Thanks in advance!
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Hmmm. Too many pontiacs, not enough chevy trucks yet.
backinblack is offline   Reply With Quote
Old 07-29-2003, 10:21 AM   #2
backinblack
So, I'm assuming no one here has had to change the plastic cam? PLEASE help a fellow truck guy! Got to drive my truck to work, and now the column is all apart.
Thanks...................
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 07-29-2003, 10:38 AM   #3
JimKshortstep4x4
Smile
I believe that there may be screw that comes in from the bottom, but it may just snap in.
I can look at a TS switch tonight and let you know if you still don't have it resolved.
Jim
Old 07-29-2003, 11:01 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I replaced mine a couple years ago, but I'm drawing a blank. I'll take a look after work this evening also.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-29-2003, 02:44 PM   #5
backinblack
Thanks guys! As of 1:00 pm, I still dont have resolved
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 07-29-2003, 08:49 PM   #6
JimKshortstep4x4
Smile
There is a zink diecast pin that snaps into the cam from below and it aligns the cam/turn signal switch to the housing. The turn signal lever is fastened to the cam with a screw that threads into this pin. I assume that you have the lever off. With the lever off and the tin strips removed, you should be able to take a thin bladed screw driver and pry the cam away from the turn signal switch. The cam has a hex hole that fits over the diecast pin. I just dissassembled one and it came apart easily.
Jim
Old 07-29-2003, 08:59 PM   #7
backinblack
Hey thanks Jim!!
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
