Old 04-17-2014, 07:45 PM   #1
Houston Ben
Houston Ben's Avatar
A/C wiring
Hi All,
I bought the Dirty Dingo AC high mount for sanden compressor but was wondering how to wire it up. I have searched around but couldn't find the site where someone had said how to wire it up. My 86 came with A/C and I was planning on using the same system but with the sanden. Will the two wires (green and black) that went to my old compressor work or is there something else I need to do?
Any help will be much appreciated!
Houston Ben is offline   Reply With Quote
Old 04-20-2014, 03:32 AM   #2
bh86
Re: A/C wiring
I might be wrong but this should be the same no? http://67-72chevytrucks.com/vboard/s...d.php?t=624688
bh86 is offline   Reply With Quote
Old 04-20-2014, 08:22 AM   #3
truckdude239
truckdude239's Avatar
Re: A/C wiring
It will work with the stock wires all you need to compressor to run is a hot and ground at the clutch so the stock system will work
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-20-2014, 10:29 AM   #4
Houston Ben
Re: A/C wiring
I'm not runing it through the PCM, trying to keep it simple, thanks guys!
Old 04-22-2014, 08:45 PM   #5
Iceburgh
Iceburgh's Avatar
Re: A/C wiring
Not running through the PCM it is real simple.
The compressor will have a ground wire on it that can go directly to the mount for a ground.
Hot wire comes from a 25 amp switched wire.
Run a hot wire to the on off switch in the cab...from the other side of the switch out to the compressor. I believe on my sanden it is blue wire
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 04-22-2014, 09:11 PM   #6
Houston Ben
Re: A/C wiring
Thanks Iceburgh, got another question for you. What fitting/connections did you use to hook up your A/C lines to the sanden compressor? Is there an adapter I can use for my stock connector fittings? I found some on ebay but I don't know which will work best.
Thanks again!
Old 05-03-2014, 09:33 AM   #7
Houston Ben
Re: A/C wiring
Does anyone know how to wire a sanden compressor?? My compressor only cam with one black wire attached???????
Old 05-03-2014, 01:44 PM   #8
dayj1
Re: A/C wiring
The single black wire is for the A/C clutch. You want to provide 12 volts to it when you want the AC on. Depending on exactly what setup you have, it can be wired different ways. Generally, for safety, you want to wire the 12V to the A/C clutch through a low and/or high pressure switch (or trinary switch if you're running electric fans).
dayj1 is offline   Reply With Quote
Old 05-03-2014, 04:19 PM   #9
Houston Ben
Re: A/C wiring
Thanks for the info dayj1. Looking at my original AC system I have some questions on the wiring.
On the original wiring
So if I give the two light green wires ignition hot and hook the dark green wire to the black wire on the sanden will this be the correct wiring?
Old 05-03-2014, 10:04 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: A/C wiring
You need to hook a test light up to the power wires and see which one cuts on when you turn the AC switch on/off on the dash. This will be the wire you want run to the black wire of the compressor. The wire connected to the acumalator are one dark green and 2 light green. One of those is power in and the other should be power out. You should tie into the power out side for the compressor. I know it's for a 71 chevy truck but the principal is the same in the link I posted about mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=580612
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-03-2014, 10:40 PM   #11
dayj1
Re: A/C wiring
The dark green wire that went to the old compressor will go to the single black wire on the Sanden compressor. The light green wire should get 12V when you turn on the AC in the dash controls (there's no need to add any new wires for that).
Old 05-03-2014, 10:42 PM   #12
Houston Ben
Re: A/C wiring
Cool, Thanks Andy and dayj1!!
Ben
Old 07-30-2014, 11:42 PM   #13
Mayfield
Re: A/C wiring
So I'm in the process of wiring my AC compressor in my 85 c10.
The wire on the right side is what originally went to my factory compressor. The wire on the left, (light green)I'm not sure about. It appears that it was never hooked up, and my ac worked before the swap.
I don't have 12v, on the original ac compressor plug, when I turn it on in the cab, but I do on the light green wire.
Mayfield is offline   Reply With Quote
Old 07-30-2014, 11:45 PM   #14
Mayfield
Re: A/C wiring
No voltage on the original plug with ac switch on in the cab, black wire is grounded to the chassis.
Old 07-30-2014, 11:47 PM   #15
Mayfield
Re: A/C wiring
12v on this wire, when switched on.
Old 07-30-2014, 11:49 PM   #16
Mayfield
Re: A/C wiring
Ohm out dark green wire from plug to accumulator.
Old 07-30-2014, 11:55 PM   #17
Mayfield
Re: A/C wiring
Ohm'd light green wires. Sorry for all post, for some reason, I can only post one pic at a time.
I'm confused, why I don't have 12v on the compressor plug, but I do on the single wire. Where does it go? Any help would be greatly appreciated.
Need some guidance on what wire goes where. Thanks
Old 08-03-2014, 12:36 AM   #18
EightiesOnly
EightiesOnly's Avatar
Re: A/C wiring
I just got A/C going on my swap and this is what I found. The light green wire gets power when you have the A/C on. It flows through the low pressure switch on the dryer/ accumulator, THEN through the dark green wire. On that A/C wire connector the light greens are tied together at the terminal, you need to leave them that way. I had the exact same problem on mine until I traced both the dark and light green wires.
It works like this...
Trace the light green wire from your low pressure switch on the dryer and see where it ends. If its not tied to the light green wire that you're getting 12V to, tie them together. It appears that they are not because you are testing the voltage at one of them.
If they are tied together, perhaps you have a bad low pressure switch.
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
