Old 04-17-2014, 10:48 PM   #1
Texasbigblock
Texasbigblock's Avatar
PS pump help!
Hey everyone,
I'm in need of some help with my power steering. My power steering pump on my truck whines non stop. I've bled it by turning it lock to lock and just can't get the whine out. Also, the pump builds up extreme pressure to the point where it'll blow the cap off. The fluid always is foamy so I figured I must be getting air in somewhere but the pump doesn't leak a drop when the truck is off and sitting so It seems like there aren't any leaks in hoses or anything. Anybody have any ideas? The ps pump and hoses are only a couple years old. I've taken out the valve and checked it and everything is working fine there.
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 04-18-2014, 10:33 AM   #2
AirSpeed
AirSpeed's Avatar
Re: PS pump help!
Does tightening the belt help with the whine? Maybe clean the pulleys and belt. I had an issue with mine years ago, it was blowing fluid out but it turned out I had overfilled it.
AirSpeed is offline   Reply With Quote
Old 04-18-2014, 11:57 AM   #3
Texasbigblock
Re: PS pump help!
The belt is tight and almost new, as are the pulleys. Even when the pump is almost dry it will still get foamy and push what little fluid it has in it, out so I know its not overfilled.
-Scott-
Old 04-18-2014, 12:49 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: PS pump help!
Some pumps just don't last. I replaced the PS pump in my truck 3 times in 3 years before I got one that wouldn't whine, and give me fits. That was 6 years ago, and it still works just fine.
I always install just the pump, and not the pump/reservoir combo.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
