04-18-2014, 12:52 AM | #1 |
1974 Gas Tank Probkem After Powder Coating
I had my gas tank powder coated and the over flow tube came off of the tank yesterday.
I am guessing the heat from the oven loosened it up. I put my hand inside the tank and it had a white substance in it.It looked like wax or a bar of soap only harder. What could that be? I took the tank to the local car wash and vacuumed it out but I am wondering if it is a sealant that was melted do to the heat of powder-coating? |
04-18-2014, 01:35 AM | #2 |
Re: 1974 Gas Tank Probkem After Powder Coating
you could remove the solder and get it welded. the talk may have been kreem'd if its like a glaze
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
04-24-2014, 09:10 AM | #3 |
Got my answer
I put the tube back in with some tank epoxy and the hard white substance ended up being plastic beads melted together.They used them to blast the tank prior to coating it and they fused together in the bottom of the tank while it was in the oven. All is well. |
04-24-2014, 10:48 AM | #4 |
Glad it all worked out for you. Thank you for the update. Goes along way when using searching the board for answer/help.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
