04-18-2014, 10:52 AM | #1 |
Can I use 92 donor truck on my 68?
I recently acquired a 68 GMC C30 Dually Flatbed and shared my find with a close friend. He has a complete, running 92 Chevy C30 Dually that he's offered to give me as a donor for the changes I pan to make to the suspension of my GMC. Can any of you tell me if this is a worthwhile donor for suspension pieces? I've read a number of threads on the forum that recommend using a 73-87 as a donor, but haven't found much on using this era truck. Also, the donor has Alcoas on it which I very much would like to put on my GMC. Any help, suggestions or insight would be very helpful and greatly appreciated. Thanks in advance.
04-18-2014, 12:53 PM | #2 |
Re: Can I use 92 donor truck on my 68?
The frame changes after 87 on the trucks and after 91 on the suburbans. The earlier stuff s more of a direct bolt in and the later stuff will not bolt up. That is why the 73 to 87's are the donor of choice.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-18-2014, 12:58 PM | #3 |
You can use the motor and trans but you will have to feal with the motor being fuel injection the only other that will be reall useful is the seat
70 SWB STEPSIDE 70 BLAZER 09 challenger |
04-18-2014, 07:30 PM | #4 |
the boat guy
Got a sawzall and a welder? You can do anything!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
