piston question
I have a 350 that has a spark plug that keeps gumming up. Am I right in thinking its the piston ring? If so, do I re-ring just the one or all eight? If its not the piston ring what is it?
Re: piston question
It's likely a valve seal.
Clean the plug real good or use a new one, run it awhile (go for a cruise), pull the plug and look for oil on the plug threads. The only place that oil will come from is a valve seal that's caput. |
Re: piston question
I didnt even think about the valve's. Ill try you test out. Thanks...
Just here to tinker
Re: piston question
First thing you should do is a compression test. This will tell you the condition of your rings and/or valves. If you test it and have low compression numbers, add a teaspoon of oil to the cylinder with low compression and test again. If the compression rises after that, you have worn rings.
One thing you can do (as a band aid) if you do not want to repair anything right now is run a hotter plug. That will help burn the oil off of the insulator and keep it from gumming up.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
| Bookmarks |
