Old 04-18-2014, 01:02 PM   #1
BADAZ chevy guy
BADAZ chevy guy's Avatar
heater hose roughting.
I pulled the radiator out yesterday on my 77 C10 and saw that one of the heater hoses went to the top of the radiator on the Pass side (I think that one is normal) and the other went to the intake manifold instead of the water pump. (I don't think that's normal)
Can you guys take a look at yours and let me know how they're hooked up?
Thanks!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-18-2014, 02:23 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: heater hose roughting.
That's correct routing you have.
Cars were typically the ones that routed from intake manifold and water pump. GM did it various ways over the years on various models.
Old 04-18-2014, 04:29 PM   #3
wilkin250r
wilkin250r's Avatar
Connected to the intake manifold is correct, hot water coming out of the engine is going into the radiator core.
I believe automatic transmissions had the heater hose routed back to the radiator, probably to provide a little bit of early heat to the transmission cooler inside the radiator. Manual transmissions had the heater hose routed back to the water pump.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 04-20-2014, 12:43 AM   #4
Squareforceone
Squareforceone's Avatar
On my 84 they go to the rad and intake can somebody tell me which goes where currently I have the top to rad and bottom to engine I believe
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 04-20-2014, 07:32 AM   #5
MalibuSSwagon
My truck is a factory manual trans and has the heater core output connected to the radiator.
MalibuSSwagon is offline   Reply With Quote
