Old 04-18-2014, 04:51 PM   #1
47thriftmaster
47thriftmaster's Avatar
Need help from the GMC experts
I was trying to find an answer but did not have any luck. So I was wondering if anyone know which Tach works with the GMC 351 V6 engine, V8 or L6 Tach? Those are the only two I have seen or does it have it's own unique tach? Thank you in advance for the help.
47thriftmaster is offline   Reply With Quote
Old 04-18-2014, 04:57 PM   #2
jmader
jmader's Avatar
Re: Need help from the GMC experts
I recently parted out a 67 GMC with the 351 and it had the L6 tach but I never tested it to know if it worked. Tom (Tbone1964) would be the guy that knows for sure.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 04-18-2014, 06:30 PM   #3
jabborabbo
jabborabbo's Avatar
I suspect the L6 tach would work just fine...it's calibrated to count 1 crankshaft revolution for every six distributor firings...whether the engine is an L6 or V6 or a radial 6 or whatever shouldn't matter.
Tbone1964 or SS Tim or Bruceman1968 can confirm....
jabborabbo is offline   Reply With Quote
Old 04-18-2014, 06:44 PM   #4
hugger6933
The 6 cyl tach will do fine. If your not trusting that, get a cheapo tach from somewhere and make temp hookups with it in the 6 cyl position. Alot cheaper than frying or trying OE.
hugger6933 is offline   Reply With Quote
Old 04-18-2014, 06:46 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
Should be a 6 cyl tach for 6 cyl engine you need.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-18-2014, 09:55 PM   #6
47thriftmaster
Thank you to everyone, that is what I thought. Figures I have a perfect V8 tach dash that is useless for me. Well on to the search for a l6 tach, I really appreciate the help.
Old 04-18-2014, 10:11 PM   #7
The tach just counts RPMs,so only needs to know how many cylinders it's counting. It doesn't care where the cylinders are as long as they rotate on the same single axis.
