Just here to tinker
Just scored factory wheels, need tire sizes
Hey guys, I just scored some factory steelies and was wondering what size tires you are running? They are going on my 1/2 ton swb. I was thinking P255/60r15. Anyone have pics of this size tire on the factory steelies?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
Slots go on anything!
Re: Just scored factory wheels, need tire sizes
235/75 should be close to the stock size. 255/70 and 275/60 will all be about the same height. I ran 255/70 on the rear of my last couple of trucks, and it fills the wheel wells really well in the rear on a lowered truck as well. The 275/60 might be a little wide for a 7" wheel though.
1974 Jimmy- 5.3/4L80e/NP241 |
Just here to tinker
I guess I should've mentioned that I don't want the factory size. I just wanted to see the P255's to see how they sit on the rim. I like the tires to balloon a little bit.
i could show ya soon as i figure out how to load a pic
255/70 to fill out wheel wells best.
I run 255/60r15's on my Camaro. I think they would look small on a truck unless it was lowered. We'll see if somebody posts a pic.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Just here to tinker
Here is my truck currently with 275/60r15's. It is lowered 2/5. The reason I was thinking 255/60's was because these tires are 60 series and I like the way fill up the wheel well. Do you think 255/70's will have a similar effect?
255/60 will be shorter and narrower than a 275/60. 255/70 will be taller and narrower than a 275/60.
60's have a shorter sidewall height vs 70's given the same section width (255/60 is shorter vs 255/70).
Just here to tinker
Thank you! That was the response I was looking for.
Here's a calculator that gives a visual comparison>>> http://www.tacomaworld.com/forum/tir...5r15-255-60r15
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
This size calculator will help you find the difference between them.
http://www.miata.net/garage/tirecalc.html |
#13 | |
#14 | |
315/55-15 rear
#15 |
I use the calculator that always works (the one on my phone or desk or piece of paper & pen in front of me).
#16 | |
Just here to tinker
#17 |
Or a coffee shop napkin? I've used those lots of times
#18 |
Well.... no coffee shop visits here. Now, bar napkins.....
#19 |
Those work also, but after an hour or so I find I cant read them as well. lol
#20 |
Just here to tinker
Welp, went down to Les Schwab and just had them swap the aluminum mags out for the steelies and I kept the 275's. I'm actually pretty happy with it!
![]() Sorry for the dark pic…it's raining here. Go figure.
#21 |
Why not just paint/coat the alum wheels black? Less weight for sure....
#22 |
Just here to tinker
Mostly I hated the rivets in them and the fact that you couldn't put a beauty ring on them. I may want to go that route in the future so I needed the steelies. I held them side by side this morning and the steel wheel is only heavier by maybe 3-5 lbs at best. No big deal.
#23 | |
http://67-72chevytrucks.com/vboard/s...66&postcount=6 |
| Bookmarks |
