Old 04-18-2014, 08:32 PM   #1
Larry64
Passenger Side Lower Door Piller Front
1964 short step. I have cut out the front cab support & the front lower piller almost to the lower door hinge because of rust thru, also a lot of the floor. I didn't take any measurements & am now in a bind. Can anyone tell me the measurement from the lowest door hinge hole to the top hole in the door piller, or a way out of this mess?
Thanks Larry
Larry64 is offline   Reply With Quote
Old 04-21-2014, 03:51 PM   #2
Larry64
Re: Passenger Side Lower Door Piller Front
Anyone. First time I have seen a question unanswered.
Thanks Larry
Old 04-21-2014, 03:56 PM   #3
mark 66
not sure I understand the question. in your first post you said you removed pillar below lower hinge. do you need the measurement from the lower bolt hole of lower hinge to bottom of pillar?
mark 66 is offline   Reply With Quote
Old 04-21-2014, 05:13 PM   #4
evan396
larry, is this what your looking for, if it is let me know and my dad can take a better measurement. evan396Name:  IMG_3229.jpg
evan396 is offline   Reply With Quote
Old 04-21-2014, 05:16 PM   #5
Larry64
even396 That is perfect. Thank you very much.
Larry
Old 04-21-2014, 05:20 PM   #6
Woogeroo
Larry64,
It was a holiday weekend where folks meet up with family... it happens several times a year. People can only reply to a post if they actually see it.
Take care,
-W
Woogeroo is offline   Reply With Quote
Old 04-21-2014, 05:32 PM   #7
Larry64
Woogeroo thanks for reminding me. I'm retired so every day is a holiday. evan396 did a great job with the pictures I needed.
Larry
Old 04-21-2014, 06:41 PM   #8
hemifalcon
Just measure from the other side unless you've cut that as well.. Or--hang the door on the top hinge point and measure down from there for the new A-Pillar bottom.. Next time--measure before cutting..
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
