Old 04-19-2014, 12:54 AM   #1
desertdogg
desertdogg's Avatar
Upper A arm bushings for 72 c10
Im installing my suspension and have noticed my upper a arm bushings are shot I have called around for these and they all say needs to be special ordered. Does anyone know if other bushings will work ? like from a chevelle or anything ? thanks trying to get this done by tomorrow and any help would be apreciated.
Trying to get thru my LS swap
desertdogg is offline   Reply With Quote
Old 04-19-2014, 08:31 AM   #2
crossfire84
crossfire84's Avatar
Re: Upper A arm bushings for 72 c10
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 04-19-2014, 11:25 AM   #3
SCOTI
SCOTI's Avatar
No car bushings work for the 6x-72 a-arms.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-19-2014, 11:44 AM   #4
kerber63
kerber63's Avatar
If your local parts places carry Moog, ask for part K6098. That's the whole upper cross shaft with bushings and grommets. If you don't want the whole shaft assembly (probably $40-$60 at a parts store, $25 from rockauto), truckancarshop.com sells just the steel bushings.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 04-19-2014, 12:27 PM   #5
michael bustamante
michael bustamante's Avatar
Rockauto has good deals on them
1967custom
michael bustamante is offline   Reply With Quote
Old 04-19-2014, 12:42 PM   #6
desertdogg
desertdogg's Avatar
thanks for the info guys !!
Old 04-23-2014, 02:20 PM   #7
mcm1209
mcm1209's Avatar
What did you end up going with?
mcm1209 is offline   Reply With Quote
Old 04-23-2014, 08:37 PM   #8
desertdogg
desertdogg's Avatar
I ended up gettine a complete front end rebuild kit just another bump on the road but it needed it, at least it will be a nice and tight front end when its done
Old 04-23-2014, 09:04 PM   #9
Malamute
Malamute's Avatar
Where did you end up getting it? I was going to go with PB arms when I do my static drop but I want to do this on the cheap for now. I can always swap arms out down the road if I feel like it. I haven't looked closely at my bushings but I can guarantee that they will need to be replaced.
Malamute is offline   Reply With Quote
Old 04-24-2014, 12:35 AM   #10
desertdogg
desertdogg's Avatar
a resto parts .com its a pretty complete kit and comes with the idler arm and all the bushings and sleeves here is a link
http://stores.a-resto-parts.com/1971...ith-idler-arm/
Old 04-24-2014, 12:47 AM   #11
desertdogg
desertdogg's Avatar
I was going to replace the arms but it started to really add up and Im right in the middle of an LS swap to boot. If you have never done your front end I gaurantee you they are bad unless a previous owner did them. Mine were so bad that there was probably an inch of slop side to side on both sides upper and lowers. I figured since got it apart might as well just replace it all, alignment shops wont even look at it if its got too much play.
Old 04-24-2014, 03:23 AM   #12
kerber63
kerber63's Avatar
What brand of parts were in the kit?
1963 C10 short-wide
1963 C10 suburban
Old 04-25-2014, 12:17 AM   #13
desertdogg
desertdogg's Avatar
How can you tell ?....I have no Idea
Old 04-25-2014, 08:18 AM   #14
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used this, but when I got it, there was a lot more to the kit. ALso everything was MOOG and in original boxes.
http://www.classicperform.com/Store/.../6062SFKPT.htm
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
