400 to a 700r
what advantages are there to changing to a 700r?
Re: 400 to a 700r
overdrive, better mileage are the biggest.
bpatrol |
Re: 400 to a 700r
Pros...overdrive
Cons...a terrible 1st to 2nd gear ratio ...will last about 1/3 the life of the 400 ...expensive to rebuild when they do pop In my opinion, if you want the older overdrive, go with the 200-4R. I put one in my truck and couldn't be happier. 4 normal gear ratio's with all good shift points, and the pro's say it's stronger than the 700R4. So far so good in my 71 c10 with e 402BB in front of it.
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
Chance
![]() Join Date: Sep 2001
Re: 400 to a 700r
Hard the beat a th400. I had a 700r4 and I went back to my th400. 1st and 2nd years were too low.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
![]() Join Date: Aug 2008
Re: 400 to a 700r
Have you considered a gear vendors overdrive? One day I aspire to afford one and be able to overdrive every gear!
Re: 400 to a 700r
The 700r4 is a good transmission. Make sure you get one of the later ones which are greatly improved and much stronger. Mine is out of a 91 Corvette. The 200r can be built to be pretty strong but it will cost more to do it than a 700r. Check with a reputable transmission shop and get their opinion.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
Re: 400 to a 700r
Totally agree with Z10 the 200r4 is the weakest overdrive transmission , much weaker then a 700r4 that's why the changed to it. 200r4 are light duty at best. They did put them in trucks but nor for very long. They do have a longer 1st gear benefit and its the exact size as a 350 transmission.
The 200r4 is rarer(not better) and more costly to build up. good luck with whatever you do but most enjoy an over drive and would never go back to a 3 speed for daily driving bpatrol |
Re: 400 to a 700r
BOWTIEOVERDRIVES.COM
you cant go wrong with these guys
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
#9 | ||
"I ain't nobody, dork."
Re: 400 to a 700r
If it's behind a BBC then you'll need to have it beefed up to handle the TQ. Or stick with the TH400.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#10 | |
Re: 400 to a 700r
Art Carr, the overdrive drive pro says otherwise. http://www.carcraft.com/techarticles...mission_build/ It was cheaper for me to have the 200 built than it was for the 700..and I bought the core off the guy that built it for another $50. The guy told me it took less upgrades to make the 200 take the power vs the 700, which is why it was cheaper
#11 | ||
Re: 400 to a 700r
200-4R's were in cars like Turbo Buicks. I don't think there were any in trucks. But I could be wrong on the truck part.
The 700R4's got a bad rap when they first came out. But The General improved on them in a few years and they turned out to be a great OD transmission. But... they do have their shortcomings in performance applications and behind big torque engines in stock form. They can be made to handle almost anything. But it will cost a pretty penny to have it done. It ain't cheap to rework a 200-4R either. Gary
Chance
Re: 400 to a 700r
Gear vendors would be great to have. A th400 with a gear vendors would be my ideal set up.
#13 |
Re: 400 to a 700r
I don't want to debate it. its a matter of choice
but please please take a look at the link and tell me which one looks stouter. In stock form bpatrol Art Carr is talking performance build. and just about any tranny is great with that. Im sure that 200r4 that was built wasn't too cheap. a 400 with a gear overdrive is awesome but super pricey I believe and there is a 400 replacement with overdrive(but that would be for a high horsepower motor) http://webrodder.com/article/700r4-v...-which-is-best Last edited by bpatrol; 04-19-2014 at 10:23 PM. Reason: added |
#14 | |
Re: 400 to a 700r
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 04-20-2014 at 12:26 PM. |
#15 |
![]() Join Date: Oct 2013
Re: 400 to a 700r
walkintall54 - post some pics of your truck and engine. what size motor and what upgrades, if any? what rear gear ratio and how tall are rear tires? daily driver, or weekend warrior? have you done a search here, and other sites, on your question?
#16 |
Re: 400 to a 700r
I,m putting a stroker in it .its a k20 that I,m making into a extended cab. I really appreciate all the great info. Thanks Guys.
#17 |
Re: 400 to a 700r
Will post pics soon.
#18 |
Re: 400 to a 700r
heres a pic
#19 | |
![]() Join Date: May 2013
Re: 400 to a 700r
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#20 |
Re: 400 to a 700r
By the time you have a 700 or a 200 built for 4x4 abuse, you could be in the price range of a 4l80e. I'm not positive, just a thought. Draw back is that it will require electonics and more work to put one in. Just throwing out another option for ya! I have a 400 and a gear vendors. I traded some bbc parts for both of them and have very little invested at this point and time, however both of them need to be rebuilt and beefed up for a stupid stout 496. I don't think it's the most cost effective way to go about it, but I think it's the most reliable for my application.
