Old 04-19-2014, 11:05 AM   #1
ripper70
ripper70's Avatar
Painless harness #10206
Im connecting all my "instrument panel section" wires this morning and need a switched power source. Since im not using a ammeter both wires #986 (Origin Fuse Panel to ammeter) and # 989 (origin ignition switch to ammeter are NOT being used. Can i use either of these 2 wires for a switched 12v source?
ripper70 is offline   Reply With Quote
Old 04-19-2014, 07:28 PM   #2
airdale94
airdale94's Avatar
Re: Painless harness #10206
I believe it's actually intended for a voltage meter. If so you should be fine.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
