Old 04-19-2014, 06:57 PM   #1
Anti-Ricer
Need a fuel gauge to use with my fuel cell 90 ohm
I just bough a fuel cell from summit racing 65 Chevy c10. I'm going to relocate it to the frame and sell the one behind the seat in the cab. The fuel cell came with the a 90 ohm sending unit which won't work with the fuel gauge in my truck.I called summit they said they don't make a sending unit for that tank that fits my stock gauge that I have to buy a new fuel gauge. Ok here is my question can someone tell me what size fuel gauge I need that will fit in the stock place or post me a link.it has to fit in the hole where the old one was and fit a 90 ohm sending unit thank you.basically I need a fuel gauge I don't think mine works anyways. Just need a 90 ohm that will fit the stock location of the old gaugei hsve a 350 vortec 350 horse
Anti-Ricer is offline   Reply With Quote
Old 04-19-2014, 11:49 PM   #2
tincan1966
tincan1966's Avatar
Re: Need a fuel gauge to use with my fuel cell 90 ohm
Be just about as easy to switch the sending unit to one that is compatible with your OEM gauge. Most of the time a fuel gauge not working in these trucks is because of a bad sender, the wire is unplugged at the fuse panel, or broken where it runs along the floor under the scuff plate.
I bought a Equus brand sender at O'Rielly's for about $30 and it works fine with my original gauge.
tincan1966 is offline   Reply With Quote
Old 04-20-2014, 12:35 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I haven't confirmed this but my understanding is '66 fuel gauge is a 0-90 ohm unit where '65 and earlier are 0-30 ohm. You might check some of the aftermarket vendors (LMC, Truck Shop, etc.) and see if there is a original type replacement that has the right ohm rating.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-20-2014, 07:45 PM   #4
ray_mcavoy
I've done some research and testing on this. Most GM car fuel gauges & sending units did change over to 0 - 90Ω for 1966. However, the truck fuel gauges & sending units remained 0 - 30Ω for 1966 ... they didn't change until 1967. The GM parts catalogs only list two fuel gauges for 1964 - 1966 Chevy C/K trucks... GM#5644488 fits clusters with warning lights and GM#5644735 fits clusters with gauges.
So unless someone is making a custom gauge that I'm not aware of, I don't think there are any fuel gauges that will be a direct fit into a 64 - 66 Chevy truck cluster and work with a 0 - 90Ω sender.
ray_mcavoy is offline   Reply With Quote
Old 04-20-2014, 09:11 PM   #5
Roll'nSlo
Roll'nSlo's Avatar
I know Livorsi sales sending units that either fit your tank or they can build one. Livorsi mainly deals in marine applications but worth checking into. Just my $.02
Roll'nSlo is offline   Reply With Quote
Old 04-20-2014, 10:43 PM   #6
McCoyAZ
McCoyAZ's Avatar
Cant a guy change the ohm rating of a sending unit with a diode or resistor or something???
McCoyAZ is offline   Reply With Quote
Old 04-21-2014, 12:42 AM   #7
Captainfab
60-66 Nut
I do not think there are any 0-90 ohm OEM style gauges that are going to fit directly into your original gauge panel. You will likely need to simply look at the aftermarket offerings and see if one can be retrofitted into the gauge panel. Unless the depth of that fuel cell will accomodate an off the shelf 0-30 ohm swing arm sender.
Old 04-21-2014, 06:23 AM   #8
Fastrucken
Junior Member
Fastrucken's Avatar
I bought one from this guys when i moved my tank out back....
http://www.tanksinc.com/index.cfm/pa...rod/prd276.htm
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 04-21-2014, 07:03 AM   #9
luvbowties
luvbowties's Avatar
Smile Re: Need a fuel gauge to use with my fuel cell 90 ohm
Ditto! I did similar research, and thru 1966, the C10's DID use the 0/30-ohm sender-gauge combo.
OH, and there is no way to wire in additional resistors to "convert" the 0/90 to a 0/30 ohm sender. Using circuit theory, resistors can be wired to work at ONE and ONE ONLY level; but no way to effect a dynamically functioning system.
Lastly, some marine suppliers sell senders that use NO FLOAT. They work via a capacitive system that senses a purely vertical level that the fuel rises to inside a "tube" mounted vertically in ANY tank--you trim the tube to match tank depth.
Sam
luvbowties is offline   Reply With Quote
Old 04-21-2014, 08:59 AM   #10
luvbowties
luvbowties's Avatar
Hi, anti-ricer, check the following link to read about a probable solution to your dilemma-- hope it helps. I am using one now, and it works great. They may have one you can use--easy to install, and very accurate. They also have very good tech advice.
Sam
http://67-72chevytrucks.com/vboard/s...archid=4273044
**SORRY, use these links, too.
http://www.keitheickert.com/c-526-fu...l-senders.aspx
http://www.keitheickert.com/t-contact_ke.aspx
Last edited by luvbowties; 04-21-2014 at 09:11 AM. Reason: change/correct/add links
Old 04-21-2014, 09:13 AM   #11
Captainfab
60-66 Nut
That universal 0-30 ohm sender is probably the easiest solution, assuming that the 5 hole bolt pattern on the sender in the fuel cell is the same as the typical 5 bolt sender.
