Old 04-19-2014, 07:46 PM   #1
dhughins
dhughins's Avatar
what do you do about brittle door panels?
do you just replace them? could they be fixed? would repaintng them do any good? could you recover them with leather or vinly?
dhughins is offline   Reply With Quote
Old 04-19-2014, 09:02 PM   #2
Ziegelsteinfaust
Re: what do you do about brittle door panels?
Once they go brittle its over.
You can paint them for awhile, and I have seen it done. Or buy new ones.
I do not know if they can be covered, but a shop should be able to do something.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-19-2014, 09:21 PM   #3
Edahall
I've glued thin carpet to sun destroyed door panels.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 04-19-2014, 09:21 PM   #4
79Betty
79Betty's Avatar
I covered mine in fabric u find at wally world. One piece per panel. Happy with how it feels but deffinetly learned as i had to cut and glue the top n around the handrest so it looks crappy but otherwise great!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 04-19-2014, 09:51 PM   #5
dhughins
dhughins's Avatar
I like that panel. Not for my truck but would be awesome in a 4x4. I might paint them and see how they look and then try to cover them with material if I don't like the paint.
Old 04-19-2014, 10:23 PM   #6
Mr.green
I am currently redoing all the interior panels in my 78 crew cab. I am using SEM products. I was scared to take my old panels off. They are turning out really good
Mr.green is offline   Reply With Quote
Old 04-20-2014, 07:17 AM   #7
MalibuSSwagon
Spray-on bedliner from Duplicolor. Durable and gives it a nice texture while filling in the scuffs and divets.
MalibuSSwagon is offline   Reply With Quote
Old 04-20-2014, 09:36 AM   #8
daryn67
Wrap them in vinyl
daryn67 is offline   Reply With Quote
Old 04-20-2014, 09:41 AM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
that camo one looks real nice... a buddy of mine used body putty to fill in the cracks and re spray them with SEM
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-20-2014, 12:40 PM   #10
1774btcrew
1774btcrew's Avatar
Originally Posted by daryn67 View Post
Wrap them in vinyl
I am all for this idea as I don't feel there are any decent quality aftermarket door panels out there. Do you have more close up pictures and info on what is involved?
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 04-20-2014, 01:03 PM   #11
dhughins
dhughins's Avatar
Do you have pictures of the vinyl process?
Old 04-20-2014, 04:11 PM   #12
K5owner
I would imagine that a binks glue gun and some keyston industrial glue was involved or needed if you want that vinyl to adhere to the panel for any significant length of time. Also the more pliable leatherette and a heat gun will be needed of you will get lots of small wrinkles.b
K5owner is offline   Reply With Quote
Old 04-21-2014, 07:47 AM   #13
daryn67
Start by disassembling and cleaning similar to prep work to re dye plastics.
Old 04-21-2014, 07:50 AM   #14
daryn67
I started at the top, using spray vinyl top adhesive. Didn't do the whole panel, just a section at a time so as to make it easier to adjust as needed. First panel took three tries using new vinyl and nasty cleanup of adhesive in between tries.
Old 04-21-2014, 07:55 AM   #15
daryn67
Trying to find a place to work the excess material into a place that is hidden, such as the opening at top where the handles are and trim covers will hide it is the key. The transition from arm rest hump to map packet space was the hardest to get right, and heat does help but I have a great respect for guys that make the vinyl flow and look natural after they are done.
Old 04-21-2014, 07:57 AM   #16
daryn67
Connor Sweet has this down to an art, and after doing mine myself I chose to send some spares to him because of his quality.
Old 04-21-2014, 08:30 AM   #17
05duramaxhd
Conner does GREAT work here is the set that he did for me.
05duramaxhd is offline   Reply With Quote
