Old 04-20-2014, 02:45 AM   #1
Mike Foye
Oil pressure problems...
First off yes I checked and used the search tool. I am having oil pressure issues. The motor has about 1000 miles or so on it. Its the 235.5. While driving it is running about 40 psi and unless I gear down and run out the gear before I stop she loses oil pressure. On start up she has about 20 and at any other idle she is normal. The only time I have issues is when I am driving and push in the clutch and dont run the gea down.
I am running 15w40 rotella
Mike Foye is offline   Reply With Quote
Old 04-20-2014, 12:40 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Oil pressure problems...
It sounds like the crankshaft thrust main bearing has excessive clearance, you might try grabbing the harmonic balancer/pulley and see if you can move the crankshaft back and forth (front to back) by hand.
Livrat is offline   Reply With Quote
Old 04-20-2014, 12:47 PM   #3
magicoolbus
magicoolbus's Avatar
First, not to doubt, are you sure it is a 235? That is an earlier era block. IIRC the 6 cyl engines available were 250 or 292 (chevy), GMC had others. Does your engine have a spin on oil filter?
The 235 is a low pressure block and 20-40 are very normal.
What does 'running the gear down' mean?
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 04-20-2014, 03:17 PM   #4
Mike Foye
It doesn't have any type oil filter spin on or cartridge. I will double check but I am pretty sure its a 235.5 Running down the gear means using the gear to slow myself instead of using brakes .
Old 04-20-2014, 09:02 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Do you lose oil pressure turning corners, braking, or accelerating? The reason I ask is because I have a '67 with a 454 in it and the oil pressure is good unless I am turning corners, braking, or accelerating, then it loses oil pressure. I think the screen may have fallen off of the oil pump pickup tube. If I put an extra quart of oil in it it doesn't lose pressure no matter how I drive it. Just something else to consider....
I am going to drop the pan on mine to check it out this next week.
LockDoc
Leon
Old 04-20-2014, 09:17 PM   #6
Mike Foye
Just on quick or sudden stops
