Old 04-20-2014, 12:40 PM   #1
ridingreiss16
Engine Bay:
Need a little help, the guy we bought my truck from did not take care of the truck, starting yesterday I opened the hood and started cleaning up all the hanging wiring in the engine bay and what not. After I moved all of his rigged up wiring re-grounding things and what not, it looks a lot better. Now I need to take it to the car wash and spray all the dirt and grease off, what areas should I avoid, and also what is a good degreaser to use to get gunk gone? Thanks!
ridingreiss16 is offline   Reply With Quote
Old 04-21-2014, 09:14 AM   #2
bigd65
bigd65's Avatar
Re: Engine Bay:
SUPER CLEAN in the purple bottle.... Works great, so does the MEAN GREEN... THE PURPLE SUPER CLEAN, you can actually see it work
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 04-21-2014, 09:24 AM   #3
TheBlueBomber
TheBlueBomber's Avatar
Re: Engine Bay:
And if the grease is really bad a putty knife/spoon works well getting the initial grease off.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 04-21-2014, 09:59 AM   #4
ridingreiss16
Re: Engine Bay:
What areas should I avoid when pressure washing the engine and stuff?
Old 04-21-2014, 11:09 AM   #5
TheBlueBomber
Re: Engine Bay:
Electrical stuff and the carburetor. I take aluminum foil and squeeze it around connectors and stuff just as a precaution.
Austin
Old 04-21-2014, 12:01 PM   #6
thefraze_1020
thefraze_1020's Avatar
Re: Engine Bay:
I'm so glad you started this thread, because I'm about to do the same thing to my engine bay in my truck (I just pulled the engine).
Cameron
1984 Chevy C20 Custom Deluxe
thefraze_1020 is offline   Reply With Quote
Old 04-22-2014, 11:06 PM   #7
DREAMER1
DREAMER1's Avatar
Re: Engine Bay:
I did the Purple power degreaser...let it set over nite, sprayed more in the morning, let it set a couple hours and then sprayed it again and then sprayed it with a pressure washer. I did it like that 2 days in a row
DREAMER1 is offline   Reply With Quote
Old 04-22-2014, 11:23 PM   #8
tinydb84
tinydb84's Avatar
Re: Engine Bay:
Get the marine clean from por 15. That stuff will cut through any grease. You can also take it to a steam cleaner and get it spotless (and not get all dirty doing it) for around 100 bucks.
David
Instagram: myfabguy
