Old 04-20-2014, 12:48 PM   #1
riot936
Porter built steering
Ok I have a 63 currently awaiting for the arrival of an EXTREME dropmber. I found a link saying I need 3 steering joints and a heim for support and another saying I can run 2 and no support Heim. So from real world experience WTH do I need?? I found "kits" bit I'm trying to get this thing in on a budget and am trying to collect I can from swap meets and eBay. Thanks in advance.
63 knee knocker
Porterbuilt,Ls 5.3,smoothies.
"Getcha' pull"
**signature space is not a classified section, thank you**
riot936 is offline   Reply With Quote
Old 04-20-2014, 01:00 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Porter built steering
Here is a 67-72 at TUCKERS and don't cheap out on steering parts seems to be a life saving thing.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-20-2014, 10:55 PM   #3
Spragg
That pic does not look like the extreme dropmember. I got the steeing kit from PB, only 2 joints.
Spragg is offline   Reply With Quote
Old 04-21-2014, 12:55 AM   #4
Captainfab
60-66 Nut
In the pics above, that looks like an OEM crossmember, with CPP tubular arms and a rack and pinion conversion.
To the OP, I'd give Porterbuilt a call and get the skinny on what you will need. There are a few trucks in the 'Projects and Builds' section with dropmemners. You might be able to see what others have done by looking over there.
Old 04-21-2014, 08:41 AM   #5
wayno
Nate and team will hook you up with what you need... but in truth it's exactly what you see here in that picture - essentially the two knuckles and new piece of bar that goes between them.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 04-21-2014, 11:28 AM   #6
LVPhotos
LVPhotos's Avatar
Yes it is not the PB crossmember. But the rack is still I the same spot. I just happened to take these for reference for my truck.
Old 04-21-2014, 12:03 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
The rack on an Extreme Dropmember truck is higher up in the chassis.
With a stock steering column you can get away with 2 joints.
The Mild and Touring Dropmembers will require 3.
Keith
Convert to disc brakes.
Old 04-21-2014, 12:13 PM   #8
LVPhotos
LVPhotos's Avatar
That sure looks like two joints. I know about the c-notch I have a dropmember and just helped my neighbor weld in the notches. Sorry for the inconvenience. It seems I'm the only one with pictures of steering linkage. It's still in the same position. Yes the rack will fit higher. And its not a 60-66 frame it is 67 to 72 frame. And no headers or other stuff that gets in the way. Like its that hard to figure the shaft will be less than 2" shorter.
