Big Block motor stands
I went and paid a lot($176, only cuz I couldn't find any) for a nos set of BB 67-71 motor stands for my 67. I presume I use a different set of motor mount for my 1983 454 that came out of a motor home? Thanks for any and all info you can give me.
Re: Big Block motor stands
68-71 big block do use there own mounts that are pricey I think lmc had them for $80 per side. If you on a budget you can use small block 67-72 mounts they are only about $10 each that's what I used on mine
do the small block motor mounts hold up as well, and what is the difference?
I used stands from an 84 in my 72. $60 and I was ready to go. Had to drill a couple of hole a on the cross member and put in new grade 8 hardware.
fisherman56
Hi got some from my 1970 402bb 400trans will seal 110.00 plus shipping |
