04-20-2014, 08:25 PM | #1 |
Any ideas, how to fix this?
I have three of these broken on my dash insert. I was thinking about drilling a hole and threading (or using epoxy) a bolt, similar to an air cleaner.
Any one fixed this or have any ideas? [IMG][/IMG] [IMG][/IMG]
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
04-20-2014, 09:09 PM | #2 |
I know the pieces fit
Re: Any ideas, how to fix this?
Someone here epoxied bolts to the back, I was reading the thread a few days ago but don't recall who it was.
04-20-2014, 09:54 PM | #3 |
04-22-2014, 12:21 PM | #4 |
There also was a thread on here a while back about somebody mixing super glue and baking soda (?) to glue the plastic back together.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-22-2014, 05:27 PM | #5 |
I use crazy glue for the initial tack then mix up some JB weld for the long term hold. Don't know how this will work for you but this method has proved excellent in many past plastic repairs.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
04-25-2014, 01:29 PM | #6 |
You should give Rapid Fix a try. It has made wonders for me on those kind of repairs. IMO A+ stuff.
http://www.rapid-fix.com/ ssxty8 Last edited by ssxty8; 04-25-2014 at 01:35 PM. |
04-25-2014, 10:26 PM | #7 |
I got a threaded rod from Fastenal, drilled holes, and attached the rods with two part epoxy. I used Gorilla, but I think most will do the job. I let it sit all night and the next day the rods held great.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
04-25-2014, 10:45 PM | #8 |
I heard PVC glue from Home Depot works too, but I have never tried it.
04-26-2014, 05:38 PM | #9 |
I just fixed mine. I had the dash off. I ended up breaking off the remaining studs and drilling them out and using 1/2 inch long screws and flat washers from the back side.;
