Old 04-20-2014, 09:22 PM   #1
zbreezen
zbreezen's Avatar
manual trannys
planning on swapping out my 4sp with a nv4500 5sp
Open to ideas and info
zbreezen is offline   Reply With Quote
Old 04-20-2014, 10:08 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: manual trannys
If you want some quick reading type NV4500 into the Google search box at the top of this page, click on the circle in front of "67-72chevytrucks.com" and click on the Google button.
LockDoc
Leon
Old 04-21-2014, 09:09 PM   #3
zbreezen
zbreezen's Avatar
Re: manual trannys
thanks, Already checked out the archives.
Was looking for opinions on whats being used out there.
The nv4500 looks a little tall to fit. I do not have a high hump floor pan
Old 04-21-2014, 10:12 PM   #4
airdale94
airdale94's Avatar
Re: manual trannys
The NV4500 is a heavy duty truck trans. If your looking for something for your 1/2 ton step side might look up the T5 or T56 6-speed.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 04-22-2014, 08:00 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: manual trannys
For a half ton, I'd do an NV3500 instead. Smaller, lighter, and overdrive. Able to hold up to modest powerplants.
Old 04-22-2014, 12:22 PM   #6
69GMCLonghorn
69GMCLonghorn's Avatar
Re: manual trannys
If you're considering the expense of installing a 5 or 6 speed, I would think buying a high hump floor would be the least of the expenses involved.
69GMCLonghorn is offline   Reply With Quote
