Old 04-21-2014, 10:52 AM   #1
merlin3
wiper motor won't shut off
on my 1972 c10 2wd i installed a new complete wire harness,new wiper motor and wiper switch now with the key on the wiper motor won't shut off i tried switching it on or off and that made no difference the only thing i did different was the new wiper motor came with a ground strap attached to it,i cut the large eyelet off,put a smaller one on and grounded it to firewall.thanks for the help.
merlin3 is offline   Reply With Quote
Old 04-21-2014, 11:55 AM   #2
Greasey Harley
Greasey Harley's Avatar
Re: wiper motor won't shut off
There are two hot wires going to your wiper motor. One is supplied from the wiper switch, the other is direct from ignition, and runs to the "reset "side of the wiper; this makes your wipers "reset" to the bottom of the windshield when you turn off the switch.
Any chance those wires got switched?
Greasey Harley is offline   Reply With Quote
Old 04-21-2014, 12:10 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Read this thread and see if it helps.....
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
The wiper motors on the '67-'72 trucks only have one hot wire. It connects to the #2 terminal on the wiper motor.
LockDoc
Leon
Old 04-21-2014, 12:24 PM   #4
Greasey Harley
LockDoc
Actually, if you read the first paragraph in that link you provided. You will see that there are, in fact, 2 hot wired supplied to the wiper motor. One comes from the wiper switch, and the other from the ignition.
Old 04-21-2014, 12:26 PM   #5
merlin3
thanks i had taken the loose black wire coming from the wiper motor plug and thought it was a ground so i grounded it ,i should have put it on the third terminal on motor.now it shuts off but won't park at lower part of windshield.
Old 04-21-2014, 12:30 PM   #6
Greasey Harley
PARK!!! That's the word I was looking for, not "reset", thanks.
