Old 04-21-2014, 09:27 PM   #1
superfly85
Will the schoenfeld headers fit 67-72?
Anybody used the schoenfeld lt headers for 73-99 on 67-72? i dont want to have to modify a bunch of stuff or pay $650 for the DTs.
superfly85 is offline   Reply With Quote
Old 04-21-2014, 10:18 PM   #2
truckdude239
truckdude239's Avatar
Re: Will the schoenfeld headers fit 67-72?
Just use trailblazer ss manifolds 140 buxs from the d ealer they clear everything
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-21-2014, 11:17 PM   #3
superfly85
Really want a set of long tubes. Dont think those manifolds are gonna flow enough for my setup.
Old 04-22-2014, 08:44 AM   #4
DjS71
They support 400/400 in the stock application. The manifolds on the LS3 Camaros support 425/420 in stock app and can be had for around the same price. If you're going much higher, why cheap out on headers?
As for your original question, I don't know for sure but they probably will if you make the switch to the 73+ motor mounts setup.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 05-03-2014, 04:40 PM   #5
superfly85
It doesnt cost that much to make more than 425hp with these engines. I would literally have 3/4 of what i have in the engine or 1/2 what I paid for the truck. So has nobody actually tried these then?
Old 05-04-2014, 02:29 PM   #6
Classic-Steele
Classic-Steele's Avatar
They fit great! I'll try and grab some pictures... the only concern would be the front primary on the drivers side hitting on the lower control arm pin if your engine is sitting too far forward. other than that there's tons of clearance. Plus they don't hang down like some of the other ones.
Classic-Steele is offline   Reply With Quote
Old 05-04-2014, 02:35 PM   #7
Classic-Steele
I'm using the factory 72 SBC pedestals and mounts in the I6 position. Again the drivers side pedestal will require slight clearancing to clear the front primary, but nothing a little heating up with a torch and hammering wont fix.
Old 05-05-2014, 11:58 PM   #8
superfly85
Pics would be great. My my adapters are supposed to set the engine in the same spot as original sbc. Is your engine moved back?
Old 05-06-2014, 07:20 PM   #9
Jon01
Jon01's Avatar
Pacesetter TBSS headers fit great. Cheap too.
Jon01 is offline   Reply With Quote
Old 05-23-2014, 01:45 AM   #10
Classic-Steele
Here are a few pics of the Schoenfeld headers. Lots of clearance everywhere...
Old 05-23-2014, 01:57 PM   #11
68Stepbed
68Stepbed's Avatar
Where do they exit?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-23-2014, 08:30 PM   #12
Classic-Steele
Originally Posted by 68Stepbed View Post
Where do they exit?
I'll grab a couple pics of that this eve. They actually tuck up into the frame pretty nicely, and also cleared the factory tabs on the 4l80e.
Old 05-23-2014, 11:26 PM   #13
crazy longhorn
Fabricate till you "puke"
Nice fit! If its not too much trouble, can you shoot a pick on the dr side, down in the clutch bell crank area? I would be curios, if they would fit stick/shift, with the oldschool mechanical clutch linkage? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-24-2014, 02:12 AM   #14
Classic-Steele
Here ya go. Pics dont go a very good job in this case... Longhorn, i doubt you'd clear the z-bar clutch linkage.
If theres anything else you need pictures of just ask
