04-21-2014, 10:22 PM | #1 |
How to remove bed ends?
Hi guys, I'd like to remove the ends off my bed to see if they can be saved or just replace them. All I can see that bolts through is the chain for the tail gate and bolt the tail gate hinges on itself.
Any help, info or pics would be awesome. Thanks! |
04-21-2014, 10:28 PM | #2 |
Re: How to remove bed ends?
i know on my stepside the box is welding by the tailgate hinge point ive seen some that are bolted, but not sure if theirs started out welded btw fleet or step
04-21-2014, 10:31 PM | #3 |
04-22-2014, 07:43 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
The fleets bed "ends" are not removable. You can get replacement panels for them but....You need to kind of piece it together, hopefully your a good welder.
I have a pickup bed trailer that had the lower part of the bed "end" rusted almost completely gone. I patched it at an angle right below the tail light socket. Hoep this helps, show some pix of your challenge also, may help
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-23-2014, 03:36 AM | #5 |
66' custom camper 327/3spd 3.5/5 drop 17"s 2013 Subaru STI stage 1, exhaust, springs, sways ect 2002 mustang Gt. Paxton novi 2000, caged, tubular everything, 441/409 hp/tq too much to list. 1994 dodge cummins, straight piped, nv4500 swapped/built too much to list. |
04-23-2014, 09:45 AM | #6 |
i just removed mine without cutting them into peices the joint where it meets the bedside is spot welded all the way up i used a putty knife to split the spots as for the rear you have to bend the small return where the tailgate joint is and it is also tacked all the way up its a pita but i got mine off all hammerred straight and back on you could never tell good luck
04-23-2014, 09:51 AM | #7 |
Here is what I used to break a lot of spots on my truck
04-23-2014, 10:38 PM | #8 |
Oh wow, that is awesome! Thank you guys!
'62 C10 LWB fleet side. 283 w/ a T5 |
04-23-2014, 10:43 PM | #9 |
Natecr, that article is exactly what I've been searching all over for.
Here's a couple pics of what I've got. You can't see the real problem because someone has covered it all up with bondo and its starting to rear its ugly head. [IMG][/IMG] [IMG][/IMG] Both sides have bondo from the bottom to about the middle of the tail lights. I hate bondo abuse
04-24-2014, 06:54 AM | #10 |
Here is a link to Eastwood co. it's a abrasive blaster to get rid of the bondo but if you are replacing the whole end you may not need it. But here is the link anyway...Vernski
http://www.eastwood.com/eastwood-50l...e-blaster.html |
