Old 04-21-2014, 10:35 PM   #1
o6r1man
o6r1man's Avatar
Hard to shift from park?!?
The steering column in my 70 is getting hard to shift from park. It was real bad this winter when it was cold but now that it is warming up it is still stiff. When you pull back on it so you can pull it down out of park it is really stiff and same to get back into park. Does anyone else have this problem and know a fix?
1970 SWB "old flame"
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
o6r1man is offline   Reply With Quote
Old 04-21-2014, 11:16 PM   #2
litew8
litew8's Avatar
Re: Hard to shift from park?!?
I've had this problem too. Not sure if it's as bad as yours though. Mine would sometimes get stuck in the Park position, like going past park. Still works OK but could probably be rebuilt.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 04-21-2014, 11:35 PM   #3
Livrat
Member #1049
Livrat's Avatar
More than likely its the 44 year old grease inside the shift collar starting to solidify. the quick fix is to spray some WD40 or liquid wrench down inside it just next to the shift lever and start working the lever back and forth, it should free up.
The correct fix would be to disassemble the turn signal housing and shift collar, clean out all the old grease and reassemble with new grease.
Livrat is offline   Reply With Quote
Old 04-21-2014, 11:58 PM   #4
litew8
litew8's Avatar
thank you
Old 04-22-2014, 09:05 AM   #5
o6r1man
o6r1man's Avatar
Thank you LivRat, looks like I will have something to tinker with this weekend..
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
Old 04-22-2014, 10:24 AM   #6
slow-1
slow-1's Avatar
I sprayed some Silikroil on mine and it fixed it right up, sprayed into column and under hood.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 04-22-2014, 10:34 AM   #7
thelonerife
thelonerife's Avatar
I've sprayed mine where the lever goes into the column before and it helped.
thelonerife is offline   Reply With Quote
Old 04-22-2014, 01:09 PM   #8
cdowns
cdowns's Avatar
40 year old moving parts like cleaning and lubrication
Old 10-31-2022, 01:02 PM   #9
oski6754
oski6754's Avatar
This answer is yet another reason why I love this board.
After several weeks of increasingly difficult shifting from park, I came across this page, sprayed a liberal amount of WD-40 into the shift lever hole, and voilą, problem solved.
Gear selection has never been this effortless! Well done, lads!
Miles
1972 GMC Suburban K15 - Custom Deluxe
oski6754 is offline   Reply With Quote
Old 10-31-2022, 02:22 PM   #10
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Mine got like that but it turned out to be the roll pin the shift lever pivots on was falling out the bottom.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-31-2022, 05:35 PM   #11
HO455
HO455's Avatar
Just to clarify. Is it hard to get our of park but easy to get into park?
Or is it hard going in and out of park?
How about once it is out of park, does it move freely?
RIP Bob Parks.
Old 11-01-2022, 09:28 AM   #12
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
If the lube and adjustment dont seem to work, and the shifter lever on the transmission is hard to move or stuck. Drop the pan on the transmission and check the nut holding the Rooster Comb. I had one come loose and it jammed up in Park. I dropped the pan and retightened the 5/8 nut and all was good again...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-23-2025, 12:12 PM   #13
EagleChief
EagleChief's Avatar
Found this thread while trying to research/figure out why my shifter was hard to get out of park over the last few weeks. It worked fine before and just started getting harder and harder to get out of park.
Sprayed some PB Blaster around the shifter, and it's smooth as butter now! Thanks to you all!!
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 12-23-2025, 02:53 PM   #14
LockDoc
The Older Generation
LockDoc's Avatar
Spray a little of that Blaster on the bottom shifter parts under the hood too...
Leon
