04-22-2014, 11:04 AM | #1 |
72 Hitch with rear tank?
Searched a bit but wanted opinions about my setup.
72 c10 short 5.3 4l60e conversion Boyd rear tank Heated springs by PO ( will correct soon with 3/5) The Truck will/does sit low so hidden hitch? *heard bad things about ECE?* Maybe a spring helper for heavy loads? LS conversion went amazing so, time for some beach trips and I want to buy a boat. 16-25ft center console for fishing I would also like to pull my bmw e36 track car to the races or Tail of the Dragon. Never weighed it. Trailer is pretty light. |
04-22-2014, 07:39 PM | #2 |
the boat guy
Re: 72 Hitch with rear tank?
That's exactly my setup minus ece hitch. I have some generic hitch with the center section flipped so the reciever is at license plate height.
You probably shouldn't tow anything... ever... lmao! Better get some tow mirrors too.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
04-22-2014, 07:48 PM | #3 |
I assume the center section is bolt on?
04-22-2014, 08:56 PM | #4 |
the boat guy
Yeah the center just bolted to the sides. Not a universal hitch it is probably for a 67-88 it is the right width and I think the bolt holes even ligned up. My fuel cell is sandwiched between the hitch and frame with a couple extra bolts so I don't have to wrestle with them both at the same time when replacing the fuel pump.
04-22-2014, 09:38 PM | #5 |
70+ ( Old Skool Club )
What did you hear that was bad about the ECE Hidden Hitch?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-22-2014, 11:39 PM | #6 |
CPP has a hidden hitch that attaches to the outside of the frame rather than the typical bottom mount so it should not interfere with the Boyd's tank. This is what I have found anyway, I have looked at a bunch to find one that will work with my Boyd tank. I have yet to buy a hitch just spent a bunch of time looking for one to work with my tank.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
04-22-2014, 11:54 PM | #8 |
Hi Windsma, Im 57 years old and have had my share or retail therapy and of all purchases in my life i contacted ECE with a defective premature sagging spring and they were top notch, bar none. Had me tape measure to verify, and promptly sent new ones with return postage paid. I just installed their stainless rear gas tank (outside vender supplied to ece) and i already had their hidden hitch installed and all is great. Not cheap, but you get what you pay for in my mind, no regrets. Support these vendors that supply specific parts (not generic crap). They stuck their neck out with money and time at a time where it was a roll of the dice, and still back their products through economic turbulence. Long after the sweet taste of cheapness comes the sour bad breath of poor quality. I realize you were just asking about ECE, not implying there was anything bad with ECE. Ps, your truck looks great. Good luck, Brian Fuller
04-23-2014, 01:46 AM | #9 |
I have the ECE hidden hitch installed with a Boyd tank in the rear and it fit great. I haven't used it as the truck isn't running yet but from what I saw of the install the hitch seemed to be fine.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread |
04-23-2014, 07:58 AM | #10 |
The ECE hitch is a bottom mount, if you use it you will sandwich the tank between the frame and hitch. Steel/aluminum/steel. An aluminum sandwich, yummy!
04-23-2014, 12:38 PM | #11 |
Well Obama took 1/2 of my bonus so...
Ill have to wait on the boat. Thank you for the feedback. After seeing one hitch ripped in half I was concerned. |
04-24-2014, 01:28 AM | #12 |
the boat guy
No problems with mine after 5 years of abuse.
