Old 04-22-2014, 12:39 PM   #1
scott 62
1962 chevy suburban 4x4 power steering conversion help
purchased kit off the web no instructions need help and pictures
scott 62 is offline   Reply With Quote
Old 04-23-2014, 01:51 PM   #2
61K10
61K10's Avatar
Re: 1962 chevy suburban 4x4 power steering conversion help
first off we need some specs of your burb. is it stock? the axles stock stock (closed knuckle?) later yr open knuckle? what kit did you buy? In the facts form at the top of the page has some info in the PS section. there is some pics in my build.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-23-2014, 05:47 PM   #3
BigSix
Search my posts - I started one about doing power on a 4x4. While a kit may help you get the box mounted and/or pump attached and spinning, the arm atop the driver side knuckle is not included in any kits I am aware of and necessary to complete conversion.
BigSix is offline   Reply With Quote
Old 04-24-2014, 01:00 PM   #4
61K10
61K10's Avatar
cutting the arm has nothing to do with adding power steering, it has to do with the turning radius. with the stock arm you will not get full turning (lock to lock on your axle) in other words, it will not turn sharp (closed knuckle axles don't turn sharp stock anyway) it makes it worse. when you shorten the arm it puts it back to stock.
1961 chevy K10
Old 04-24-2014, 08:25 PM   #5
scott 62
all stock , do i need to trim the motor mount to mount the pump?
Old 04-24-2014, 11:52 PM   #6
Captainfab
60-66 Nut
Does your Suburban have a I6 or V8? If V8 does it have the front horseshoe mount? What pump and brackets do you have? Have you checked out this thread yet?
http://www.67-72chevytrucks.com/vboa...d.php?t=561288
Old 04-25-2014, 02:47 PM   #7
scott 62
its a 350 with a short water pump and it has the horseshoe motor mount the bracket mounts off the two holes on the lower block rite where the front motor mount is. the kit is from Classic Performance Products.
Old 04-25-2014, 03:38 PM   #8
61K10
61K10's Avatar
1st is your steering box for a 4x4? with the horseshoe mt and short w/p you will need to mod the h/shoe mt and a 3 row crank pulley, and use the third grove for the p/s. for w/p and alt i used the 2nd grove. it depends where you have the alt mounted. you could go long water pump but still need to notch the h/shoe. I have a short setup and this is how i modded the h/shoe. welded in an after market p/s pump bracket. (there is one just like the one i welded in on the outside of the pump.
1961 chevy K10
Old 04-25-2014, 03:46 PM   #9
scott 62
that's what I was looking for, thank you
Old 04-25-2014, 04:19 PM   #10
61K10
61K10's Avatar
scott 62--you can see the piece i cut out of the h/s on the left. the bracket piecjust replaces the piece i cut out. weld on and bolt it back on the eng.
1961 chevy K10
