Old 07-29-2003, 01:22 PM   #1
nrgflow
Is there a 5 spd tranny that will swap into an 82?
Currently I am running an inline 6 292 with a 4 speed on the floor. The engine revs up kind of high when doing freeway driving. Do they make a 5 speed tranny that I can swap mines out with. If so, what years and models can I use?
Thanks!
Will
82 Chevy Truck LB
292 inline 6
4 spd granny
nrgflow is offline   Reply With Quote
Old 07-29-2003, 02:23 PM   #2
PHOENIX
I have asked and looked around for a nice 5-speed with an overdrive. You could get one out of a newer truck and get it to work, but it may not be what you want.
The 6-speed (1386-000-011MS) on the second link is what you really want, but $$$ is the problem
All kinds or different trans:
http://www.motivegear.com/tech_info/...nny_guide.html
6-speed:
http://www.standardtransmission.com/
http://www.standardtransmission.com/BW_T-56.html
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 07-29-2003, 02:33 PM   #3
Prerunner1982
Prerunner1982's Avatar
nrgflow, if its winding up too much on the highway you might consider changing your rear gears. what do you have now?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-29-2003, 02:35 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I am assuming a granny 4 speed, so I would suggest an NV4500 out of a 88-up 1TON. It would require a hydraulic setup most likely.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-29-2003, 05:02 PM   #5
nrgflow
Yes, I have a granny 4 speed. I am not sure about the rear gears. Can you tell by the number of bolts on the rear?
So what would it entail to convert to a hydraulic clutch setup?
Will
82 Chevy Truck LB
292 inline 6
4 spd granny
Old 07-30-2003, 01:43 AM   #6
Prerunner1982
no you cant tell by the bolts, would have to check the tap on the diff cover but its most likely not there. you could pull the cover and count the teeth or support the truck and turn the rear tires once, and see how many times the drive shaft turns (just over 3.5 times would be something close to 3:73) my truck has no problem on the highway.. it has 3.08s and 31" tires. but if i had say 4.88s it would wind up and only go about 60mph. and extra gear (trans) is always nice, but a rear gear swap might be a tab cheaper!
Jon
Oklahoma Roll Call
Old 07-30-2003, 12:53 PM   #7
Captkaos
Captkaos's Avatar
Most likely you have 3.73 or 4.10 gear being an inline 292.
As for a hydraulic clutch, you will most likely need the pedal assembly, resevior, linkage, bellhousing, slave cylinder, etc. If you could find a donor truck it would simplify it. I think 1984 was the first year offered. You can usually find them on 3/4T-up trucks also.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
