04-22-2014, 06:02 PM | #1 |
WTB. 71 BB Intake manifold
looking for a intake manifold for my 1971 402 engine. prefer jan/feb 71 date code. i belive the #'s are 3955287. correct me if im wrong.
thx,dave
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
04-22-2014, 09:31 PM | #2 |
Re: WTB. 71 BB Intake manifold
I might have one. Let me look and I'll let ya know.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
04-22-2014, 09:34 PM | #3 |
I have one, I will check the stamped code.
04-22-2014, 09:45 PM | #4 |
My intake is #3866948. It's off a BB. Pm me if ya interested.
04-23-2014, 11:58 AM | #5 |
please check and get back with me. thx
after doing a search you might have a bb intake for a 66-67 chevelle? but thx for reply.
04-23-2014, 12:48 PM | #6 |
04-23-2014, 02:26 PM | #7 |
is it 71? or 72? dave
04-23-2014, 04:21 PM | #8 |
Removed from a 71 GMC BB 402!
04-23-2014, 07:35 PM | #9 |
kool. can you find the date? thx,dave
04-23-2014, 08:29 PM | #10 |
How and where?
04-23-2014, 08:50 PM | #11 |
67-72 parts collector,…
http://www.drivinithome.com/engine-codes/
Chevrolet used both cast-iron and aluminum intake manifolds throughout the muscle car era, and the date codes are located in different places on each. The code on cast-iron intakes is normally found on top of the intake near the casting number. Aluminum intakes most always have the date code on the underside of the manifold, usually under the oil splash shield (if so equipped). This will make the location of aluminum intake date codes impossible if installed on the engine, and even if not, the oil splash shield is in most cases riveted in place
04-23-2014, 09:50 PM | #12 |
Thanks for the info, I will remove the engine pull bracket and look...
04-23-2014, 10:06 PM | #13 |
Date is stamped by the coil mount holes under the brake booster line in format like A 15 1 would be January 15th of 71. Shouldnt have to remove the intake just look under the brake booster line.
04-23-2014, 10:10 PM | #14 |
Wide n'Low
I have one as well (pretty sure) will verify and reply tonight
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
04-24-2014, 11:46 AM | #15 |
Wide n'Low
Seems mine is still buried in the trailer from the latest swap meet, will look today.
04-24-2014, 12:50 PM | #16 |
I FOUND ONE !!! can you belive i had a 71 402 burried in the back of a storage container foe over ??? 10 years and dug it out today. ####'s match and date works. and now i have a set of exhaust manifolds smog, for sale
thank you all for everything!!!!! dave
04-24-2014, 01:19 PM | #17 |
04-24-2014, 04:43 PM | #18 |
correct me if im wrong? but is the c= march? dave
04-24-2014, 07:31 PM | #19 |
pm sent
