04-23-2014, 12:56 PM | #1 |
1948 3/4 ton GMC
I've got a friend with a 48 GMC 3/4 ton and has 8 lug wheels and he wants to put disk brakes on the front and a later model 8 lug rear axle out back. The rear axle is not a problem, but finding a kit to convert the front to disk brakes
is seeming to be impossible to find. Does anyone know of a supplier who makes such a product? Or are there any newer 8 lug type of spindles that will fit the original 48 GMC front axle? Thanks Mike |
04-23-2014, 02:38 PM | #2 |
Re: 1948 3/4 ton GMC
I think we tossed that around a couple of months ago when someone else asked pretty much the same question. I'm sure that there isn't a kit available but a couple of guys with decent mechanical skills and fabricating skills along with being able to visualize e abla bit might be able to do it pretty simply.
If the front drums come off the hubs you might be able to use a 73/80 or so Chevy/GMC 3/4 ton front rotor which slips on the 4x4 hub. You might have to make or have a spacer ring made that went between the hub and the rotor to keep it centered on the hub. Then a guy would use the matching calipers that fit the front of the same truck. You would have to fabricate or have someone fabricate the caliper brackets. You might talk one of the outfits that makes caliper brackets for the rear of 3/4 ton tuckst for conversions into making a set of brackets that have a pilot hole drilled to center the bracket on the spindle but aren't finished as they would be to go around a rear axle.
04-23-2014, 05:17 PM | #3 |
I have my templates right now at the machine shop.
I'll know in a couple days what the verdict is. Here's what I'm working on. http://s1074.photobucket.com/user/wh...98174699168064 |
04-23-2014, 05:19 PM | #4 | |
Hollister Road Co.
Depending on the year 47-52 and 53 up have a different spindles, later being better. I know there will be some machine work involved and the caliper bracket will have to be fabricated. I'm doing a 47 1 ton in the next 2 weeks and have some parts lined up so as soon as I start it I'll post it. Its not going to be an off the shelf bolt on so expect a little machine work and welding. I expect the swap will be $500 or so in parts by the time I get bearings, $250, seals, $12, rotors $40 each. Calipers $80 each unless you have a core, hoses $25, Brackets $??.00, possible spacers for the disc. |
04-23-2014, 06:26 PM | #5 | |
What calipers are you using, they look familiar as i probably did a few brake jobs on the same model as the donor rig but I can't think of what they came on.
04-23-2014, 10:22 PM | #6 | |
Hollister Road Co.
04-24-2014, 01:15 AM | #7 |
The calipers are the rears from a 2003 and newer 2500/3500 van.
They're basically the same as what the Silverados and Tahoes use on the front, they just mount a little different. I'll be using the same ones on my rear also. So I'll have 13" rotors and dual piston calipers on all 4 corners. I have a 54, so it's the 52-59 spindle, which is 1.496" on the large end. |
04-24-2014, 02:58 PM | #8 | |
Hollister Road Co.
04-24-2014, 05:07 PM | #9 |
You could alway's just use the later style spindle.
Or you can have your spindle turned down to accept a tapered bearing. Again, it's more machine work, but you could have it so the seal rides on the spindle vs. the bearing, and you could have bearings that are readily availible. Take a look at the Timken catalog for bearing sizes. http://catalog.timken.com/WebProject...bookcode=trb12 There's nothing wrong with the stock ball bearings either. They have plenty of load capacity. Ball bearings roll easier and run cooler than tapers do. |
04-24-2014, 06:47 PM | #10 |
Hollister Road Co.
I have a line on some later model spindles and that certainly would be easier. Hopefully there in good condition.
Turning down the early ones I don't think would work he wants to use this truck as a 1 ton work truck from time to time so I need to err on the safe side. If Texans didn't have the habit of hauling 4 tons in a 1/2 ton truck turning the spindles would be an option. |
04-24-2014, 07:25 PM | #11 |
I looked at the Timken catalog after I sent the messege, I don't think it would do any good to turn down the early spindles anyhow. The outer bearing is an oddball size, there's nothing that would fit. It's still plausible to turn down the newe spindles for a tapered bearing conversion. At the most, you would only be taking it down to 1 3/8" which is leaving plenty of meat on the bone and not signifigantly affecting strength.
On the newer spindles, you will have to use the later kingpin also, the 48s are too short. |
04-24-2014, 08:10 PM | #12 |
Hollister Road Co.
Thanks for the tip on the pins, It needs pins anyway so I'll get what fits later ones
04-26-2014, 03:27 PM | #13 |
Hollister Road Co.
Have the spindles for a 54 on the way and bearings that should fit without much machine work
Timken for 53 to 59 1 Ton and I believe 3/4 Ton 3339/3387 1.5 ID and 3.151 OD 1975/1922 .875 ID and 2.25 OD Not sure of the assembled width but if I have to trim the hub or shim the hub it won't be much. The truck is going to the blaster this week so I won't have any work on this for 10 days or so. |
04-28-2014, 10:43 AM | #14 |
Here is the build page for my 8 lug disc conversion. I've got everything but these darn brackets made. I've made a few prototypes, and each have a little quirck that won't make them work right.
http://67-72chevytrucks.com/vboard/s...d.php?t=586788 If you want a quick rundown, 2000-2014 2500 and 3500 chevy trucks and vans have rotors that fit without any modification. The only thing you need to do is drill out the stud holes on the hub to receive bigger studs. With that, your rotors are done. Calipers come off the same vehicle, the problem with those (for me at least) is the calipers are awfully large, and would hit the rim. So I'm going to add 1/2" spacers in between the rotor and the wheel. Last piece of the puzzle are the brackets that hold the caliper to the spindle. And that's where I'm stuck right now. |
09-15-2014, 12:32 PM | #15 |
Would these work? I'm a newbie so go easy on me
http://www.ebay.com/itm/350973126802...%3AMEBIDX%3AIT |
09-15-2014, 01:44 PM | #16 |
Mechanixman, were you trying to use stock era correct steel wheels that would not fit?? Or was it an offset issue with aftermarket wheels??
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
09-15-2014, 05:12 PM | #17 |
Orrie,
I'm using the 16in ford wheels. Close enough to stock without being split rims. The place it is hitting is about where that red circle is. |
09-15-2014, 05:48 PM | #18 |
Hollister Road Co.
This kit is correct for 3/4 and 1 ton. It doesn't use any half ton pieces. Works with 16" and 17" original wheels, has a 13" disc, uses 2500 HD parts
http://www.ebay.com/itm/1947-1955-Ch...e=STRK:MESE:IT here are the install instructions http://www.thehollisterroadcompany.c...converion.html |
