04-23-2014, 03:37 PM | #1 |
Bed Replacement Question
Hey Fellas, After wearing out the original bed of my '84 3/4 ton, I replaced it with one off of a '75 half ton. Having used it for the last few months it is quite apparent that the one I just put on is not as stout as the one I wore out. Were the '70's models a thinner gauged metal, or did you get a better body with a 3/4 ton? Any insights?
04-24-2014, 11:19 AM | #2 |
Re: Bed Replacement Question
No insights on that? Maybe I am mistaken. Either way, I will put a spray in liner and build an angle iron frame to stiffen it up. Any other ideas?
04-24-2014, 01:52 PM | #3 |
RR
Should be the same metal, but if the bed has replacement panels or floors, the replacment metal could be thinner. The only significant changes that I can recall are the fuel cap vs door and tailgates.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB 1987 GMC V3500 Dump, 6.2L diesel, TH400 1983 GMC K2500 - awaiting its restoration and Cummins swap. |
04-24-2014, 05:05 PM | #4 |
That seems to be the consensus from all the people I am talking to. Thanks.
04-26-2014, 08:52 PM | #5 |
Same bed was used on all models (ie, a 1/2 ton got the same bed as a 1 ton).
By the way - on the 2014 and beyond K2XX pickup box, there is a HD box released for 3/4 ton and 1 ton. It gets a couple additional braces under the rear sills and some doublers at the attaching points. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
