Old 04-23-2014, 04:06 PM   #1
Hogger54
Hogger54's Avatar
What do you do when you find lead?
I'm working on cutting out the rust, and welding in patch panels on the cab. When I started tacking in the upper cowl panel, the metal started dripping out.
I can't tell how thick it is, but is there a trick, or procedure to welding this in?
Hogger54 is offline   Reply With Quote
Old 04-23-2014, 04:49 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: What do you do when you find lead?
Torch off what you can and while hot wire brush it. Then you have to grind the lead off so you can weld. You should be able to put some spot weld hole in the upper panel and remove the lead around those holes and weld to the lower panel that's slipped under the upper. when you done use all-metal or something similar on the seam not bondo or you could re-lead it
dwcsr is offline   Reply With Quote
Old 04-23-2014, 06:38 PM   #3
mr48chev
mr48chev's Avatar
Most bodymen do exactly what Dave said to do. Heat the lead with torch, it doesn't take that much heat and even a little propane torch on a handheld bottle will usually melt it and brush it off and then do your welding. These trucks were finished off with lead at the factory and it isn't some patch work that was done later unless the truck was damaged in that area at some time.
My ongoing truck projects:
Old 04-23-2014, 08:21 PM   #4
Mac the Yankee
wear gloves and a mask when you do- lead poisoning is NOT something you want to deal with.
Mac the Yankee is offline   Reply With Quote
Old 04-23-2014, 09:40 PM   #5
LSXapache
LSXapache's Avatar
.....melt it down and cast bullets!
LSXapache is offline   Reply With Quote
Old 04-23-2014, 11:46 PM   #6
mr48chev
mr48chev's Avatar
Proper safety equipment is a real good idea along with having plenty of ventilation and if you are working in a garage attached to the house I'd roll it outside to do it.
