04-23-2014, 08:12 PM | #1 |
Anybody have fitment issues with Sanderson headers?
I ordered a set of their coated headers a couple of weeks ago. I paid for three day shipping and got them a week later....but that's another story.
I go to pop them on last Friday and the passenger side collector hit the frame so bad I couldn't get the bolts started. The driver side bolted up but the collector was pressing against my transmission kickdown linkage. I contacted them and spoke with a guy and he said they have installed them on many trucks with no issue. I tried to explain where it was hitting the kickdown linkage and he couldn't understand the kickdown was a metal rod and not a cable. My truck is a 68 with 307 and a powerglide. Am I missing something? |
04-23-2014, 08:53 PM | #2 |
Re: Anybody have fitment issues with Sanderson headers?
I put a set of shorty sandersons on a 73 GMC, they barely cleared the bell housing. C'mon, that measruement is the same on every small block chevy out there!
04-23-2014, 11:40 PM | #3 |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
04-24-2014, 10:56 AM | #4 |
Mine were also the CC11. I would upload pictures but I'm on my phone and not sure how.
04-24-2014, 07:08 PM | #5 |
04-24-2014, 07:24 PM | #6 |
Are your motor mounts in the forward or rearward frame holes?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-24-2014, 07:27 PM | #7 |
04-24-2014, 07:54 PM | #8 |
I doubt its the case here, since you still have the small block, but I know I once tried to install headers in a '69 B-Body that still had the small block pedestals but big block mounts. Nothing cleared.
I've also run into major issues with my 502 Camaro - but that's because the exhaust ports are raised on the cylinder heads. Since you seem to have an otherwise stock collection of parts, something (like the pedestals) must be in the wrong place. That or the truck used to be a big block and it has the wrong stands, but I don't even know if you could make that work in these trucks. That kickdown part has me stymied though. The older I get the more I like stock manifolds. Sure they eat power, but how much traction have you got in a pickup truck anyway?
04-24-2014, 08:19 PM | #9 | |
04-24-2014, 08:47 PM | #10 | |
04-24-2014, 09:12 PM | #11 |
My bb8s hit my bell housing and inspection cover. Minor trim and they fit
04-24-2014, 11:47 PM | #12 |
Does the drivers side hit the frame? If not it almost looks like the engine is offset to the passenger side. I'm betting there is a mismatch with your engine stands. Mine was originally a 6 cylinder, then a 400 small block was installed and they used the 6 cylinder engine stands in the rear most position.
I change the stands out to the correct small block stands and move the engine forward to the correct position. As you can see by my photos the CC11 fit great. I was also looking at your tubes and they seem to be identical to mine. I don't think the headers are the root cause of your problem.
04-25-2014, 06:30 AM | #13 | |
08-26-2014, 03:05 PM | #14 |
Did you get a resolution to this? I am having exact same issue. My drivers side CC11 header fits fine plenty of room. My passenger side hits the frame rail. I made sure my transmission is centered and I am using the stock motor mounts. No idea why it is so far off.
08-26-2014, 03:39 PM | #15 |
Also my Motor mounts are in the front holes. I see Z10's are in the rear holes. What would be the impact if I were to move mine to the rear? I assume it would impact the drive shaft fit?
05-04-2017, 01:51 PM | #16 |
I used the CC1_158 and they fit perfect.. Summit has the best pricing and I revived the next day at no extra charge.
05-04-2017, 02:07 PM | #17 |
I never did get the issue resolved with these headers. I tried two sets from Sanderson and neither would fit. It's been three years so I can't remember all the details. I'm almost guessing it has to do with my truck having a power glide.
