Old 04-23-2014, 10:14 PM   #1
hpcgmc
hpcgmc's Avatar
67 ball joints or 73-87 ball joints?
I'm about to buy a disc brake kit. Some brands use the stock ball joints and tie rod ends and some brands use the 73-87 ball joints. Is there any reason good or bad to go with one over the other? Is the only benefit that replacement 73-87 parts will be easier to find as tie goes on?
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 04-23-2014, 10:59 PM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: 67 ball joints or 73-87 ball joints?
If you choose 73+ ball joints you will be searching for a 71-72 or 73+ center link, Or a tie rod adapter sleeve. Keep it simple and keep the 67-70 ball joints, I wish I did.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-23-2014, 11:02 PM   #3
mgchevyparts
mgchevyparts's Avatar
No reason not to use components that fit your 67 OEM parts.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 04-23-2014, 11:49 PM   #4
First c10
First c10's Avatar
I replaced all my front components with 73-87 a arms center link tie rods pitman arm ball joints. So basically it's a 73-87 under my 1970. Most part stores have on the shelf. The 67-68, 69-70, and 71-72 are there own animals. Not for everyone but I picked up a 78 1/2 ton front crossmember on CL for 75$. Rebuilt the parts and switched them out in a few hours since I had all the parts ready to go. This was a picture with all the part layer out and ready for installation.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-23-2014, 11:54 PM   #5
First c10
First c10's Avatar
Also the lower a arms are out of a heavy half 78 so by just adding them you will drop your truck 1". I did found it out by adding 1" drop springs plus 2-1/2" drop spindles and I got like 4-1/2-5" drop. So I had to put the stock springs back in. For a out 3-1/2" drop in the front.
Good luck!
GO GO!!!
Old 04-24-2014, 10:16 AM   #6
hpcgmc
hpcgmc's Avatar
Thanks for the input. I'll probably stick with the stock ball joints.
Old 03-07-2015, 09:53 PM   #7
elf w/capital T
Hmmm. Noted. Thanks for the posts everyone
elf w/capital T is offline   Reply With Quote
