Old 07-29-2003, 05:45 PM   #1
OLDCHEV4X4
OLDCHEV4X4's Avatar
can someone desktop dyno please.
I built a motor a while back and was wondering how much HP i have.
350 .030 over
10 to 1 compression
TRW forged pistons
GM PM rods
GM steel crank
Balanced and Blueprinted
492x heads(with accessory holes..hehehe)
1.94/1.50 valves
roller timing chain on zero degree
1970 LT1 aluminum intake 3972116
Lunati bracket master hydraulic cam
224/224 @ .050 duration
.460/.460 lift
GM windage tray
Road demon 625cfm carb.
Headers
GM HEI ignition with 53,000 volt coil
I built this motor to do 100 yard dirt drag racing. The more aftermarket stuff you add on the higher the class your in. So i tryed to make a specd out 72 LT1. I couldent find all the exact specs for a 72 LT1 but I think i got real close.
Thanks for any help or spec info.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-29-2003, 07:04 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Using a flow file for stock 462 double hump heads, you get:
337hp @ 5000rpm and
390 ft. lbs. @ 3500
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-29-2003, 07:12 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
Thanks Lucas.
Whats a flow file?
And does the x heads make a difference? I think they had 10cc more size on the intake runners.
Randy
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-29-2003, 08:51 PM   #4
lukecp
lukecp's Avatar
A flow file is a desktop dyno file for the amount of air a cylinder head will flow at various levels of valve lifts. For example, the 462 head will flow 167 cfm @ .300 inches of valve lift through the intake port. The 492x heads will proably flow a tad bit better because of the 10cc larger intake port, and more flow=more power .
Old 07-30-2003, 07:56 AM   #5
smokekiki
Mike
smokekiki's Avatar
Hey,Randy,where are You dirt dragging?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 07-30-2003, 04:36 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Hey Mike,
I raced at Kempton fair this year.(north of Kutztown) And in Jersey Shore PA.(west of Williamsport). And at Line Mountain Race Track south of Sunbury.
Its set up just like asphault drag racing, except its on loose dirt and its 100 yards long. Its alot of fun.
You should bring your yellow blazer out and try it.
I had some weak valve springs so i changed them. So 600 miles lator my cam is wiped out. Thats OK, I have this motor that was going in my shortbed, now its going in the Blazer..
Randy
Let me know if you want to go.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
