Bluetooth without head unit?
Has anyone tried or been able to set up a Bluetooth connection to an amp without a had unit. I was thinking it would be a good way to keep my dash original and not need anything but my phone connected to an amp and speakers
Re: Bluetooth without head unit?
Yes I have a Bluetooth unit with RCA inputs. Just connect the BT device(RCA) righ into the amp and hookup the power, ground speakers etc. the only extra work I had to do was run a toggle switch to the REM/IGN 12+ that turns the amp on and off. The reason I did that was that if the amp and BT turn off at same time you get a big pop from the amp to speaker. Turning off the amp REM/IGN first drains the power so that it doesn't pop.
Here is the BT I ordered: http://www.crutchfield.com/p_822BTRE...5494425&awdv=t My amp is a Polk PA330 and speakers are 2 kenwood 6x9 5 way speakers. Speakers are built into single box on the floor between pax and driver. Plenty of sound for the truck. Good luck! Rick. |
So how is the volume control for your sound and thanks for the link
I set my amp gain at about 50% and stuck it under the seat. After that I just control the volume with my phone or ipad. Works pretty slick.
Awesome that sounds exactly like what I want. I think I'll get a 4 channel amp though
I did the same with the bluetooth receiver to the amp but in the middle i put one of these, a JL Audio CL-RLC line level controller http://www.crutchfield.com/S-t0bZAUp...io-CL-RLC.html
It has a nice little volume 'knob' that fit in a factory hole on the underside of the dash - just to the right of the steering wheel (sorry I'd post pic but trucks in shop getting IFS installed) |
Looks like a great addition. Thanks!
I like that one too lol guess there are a few options. Does that one run on the switched power also?
I bet that the remote knobs for amp control work for volume too
#10 | |
Just something about a physical volume knob for me that can't be replaced by a smartphone (or damn touch screen infotainment systems in new cars) |
Yeah I like the knob better when I'm driving
Interesting concept, sounds like a cool way to go. Subscribed for later upgrade consideration for my truck.
Now if I can only figure a way to play 24/96 FLAC files. But thats just my personal preference for audio files.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72 1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code" 1970 Mercury Cougar "Eliminator" 351C-4V C6 1972 Ford Ranchero GT 351C-2V C6 1974 Honda XL-350 Member of the "6 C's and a D" 1-Ton Fun Club! |
#13 |
![]() Join Date: Jul 2010
That is trick piece
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#14 |
Another cool little thing I found ... a bluetooth receiver with NFC (near field communication).
I tried probably 4 different bluetooth receivers and none of them would automatically connect when I started the truck but if your phone is NFC capable with this one ![]() you need to hold the phone up close to the receiver to initiate but then i have an android app called Trigger (might be version for ios) that will automatically connect the bluetooth, start my music app and start playing music. |
#15 |
The Poweramp app plays FLAC, etc. There is a free version for Android but worth the 3-4 bucks for full version. Dunno about iPhoneys
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
#16 | |
At one point I had an iphone dock inside the ashtray hard wired to the JL audio volume controller - sound was a little better but bluetooth is much more convenient. |
#17 |
If there was a usb to rca output on for android I would use that instead of Bluetooth but I don't think I can do that... guess I might be able to use a headphone to rca cord with the jl audio knob. Hmm
#18 |
I found a dock for my gs 3 that allows me to use the charging port to play music.. I think I will mount it in the ashtray I like the fact it will charge it and has a output that I can hook up to the amp and jl knob
