Old 04-24-2014, 09:25 PM   #1
SCHRUMGMC
SCHRUMGMC's Avatar
Dash lights not working? 59 Gmc
I have replaced fuses, Bulbs.. The Gauges lights work..the indicator lights don't work, the right one flashes when I push the Turn signal lever down... Im lost here. There is a Fuse diagram under the dash where things are Grounded, could paint mess up a Ground? Where are the Grounds for this? Bad indicator housing maybe?
Could it be a bad printed circuit?
Gauges all work (I think)
Even the Dome light doesn't work..replaced that Bulb
I know some of you will say, Wiring diagram well I can't read them
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-24-2014, 09:32 PM   #2
lowrodderchev
lowrodderchev's Avatar
Re: Dash lights not working? 59 Gmc
my blazer did that when I first got it and it was the turn signal switch had to hold it down on both left and right for it to work
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 04-24-2014, 09:37 PM   #3
SCHRUMGMC
SCHRUMGMC's Avatar
So basically get a new Turn signal switch? I can hear it clicking though? On both sides
I grounded the Bar on the bed that holds the wood and the Frame, well almost got it done I then got distracted
1971 GMC Sierra
1959 GMC 100
Old 04-24-2014, 09:43 PM   #4
lowrodderchev
maybe run a tester to the wire to see if your getting a current. I'm all about trial and error test every wire from the source and down if its clicking it could be a ground but are your brake lights working they run off a ground as well I believe
Old 04-24-2014, 10:06 PM   #5
SCHRUMGMC
SCHRUMGMC's Avatar
If its clicking, then the Switch is working I assume.
Where is all of this grounded?
1971 GMC Sierra
1959 GMC 100
Old 04-24-2014, 10:36 PM   #6
lowrodderchev
dome light is grounded by housing as well as the tail lights again I would run a test light to make sure its getting power p.s. clicking aint always good my knee clicks and doc said that's very bad
Old 04-24-2014, 10:37 PM   #7
SCHRUMGMC
SCHRUMGMC's Avatar
Well I'll just buy a new Headlight switch then.I am not sure what to do
1971 GMC Sierra
1959 GMC 100
Old 04-24-2014, 11:20 PM   #8
SCHRUMGMC
SCHRUMGMC's Avatar
Well, I'll just replace both switches..
1971 GMC Sierra
1959 GMC 100
Old 04-25-2014, 12:39 PM   #9
Daze57
Daze57's Avatar
you should try testing as mentioned above - it might be something v simple - if you have exhausted all you attempts at finding the problem them you might think about getting new parts , just my 02 cents worth
Daze57 is offline   Reply With Quote
Old 04-25-2014, 01:04 PM   #10
SCHRUMGMC
SCHRUMGMC's Avatar
All the gauges work fine
Oil Reads 30
Temp Gauge, well its running over the line a hair? could it be because of the new Temp sending unit?
It runs but I can literally adjust the timing while its running..I need to get a rachet to it and tighten it down real good
1971 GMC Sierra
1959 GMC 100
Old 04-25-2014, 01:24 PM   #11
lowrodderchev
cool happy for ya did you take it to a mechanic?
Old 04-25-2014, 01:27 PM   #12
SCHRUMGMC
SCHRUMGMC's Avatar
Nope....The Distributor is still loose..I need to get a ratchet to tighten it down
1971 GMC Sierra
1959 GMC 100
Old 04-25-2014, 02:45 PM   #13
OrrieG
OrrieG's Avatar
Nope, the lamp and fitting on the dome are two prong so hot comes in and ground goes back out to the switch. Look at the attached diagram, dome ground is at the top, hot at the bottom. Purpose is so it can have variable level along with the instrument lights thru the coil resistor.
Also I do not have a factory turn signal wiring diagram, so no help there, but you should be able to test for inputs and output to see if it is the switch or wiring to the various lamps and indicators.
OrrieG is offline   Reply With Quote
Old 04-25-2014, 04:00 PM   #14
SCHRUMGMC
SCHRUMGMC's Avatar
Is my oil pressure good?
I bought a new Speedometer cable
Its a SOB to get the old one out of the grommet ughhh
1971 GMC Sierra
1959 GMC 100
Old 04-25-2014, 08:09 PM   #15
OrrieG
OrrieG's Avatar
On most chevy engines the oil gauge works like a tach, high when cold, low at idle after getting heated up, moving to middle off idle. 30# is fine, its not a race engine designed for higher pressure. Best way to calibrate the temp gauge is to bring it up to full temp and measure the water temp in the radiator with the thermostat open. Rad will read a little cooler than the head sensor location.
Old 04-25-2014, 08:35 PM   #16
SCHRUMGMC
SCHRUMGMC's Avatar
Well I cleaned the grounds....checked fuses...hell the indicator lights still don't work
It couldn't be the Lens housing could it?
The Speedometer cable won't come undone where the Transmission is? Its pissing me off, I've sprayed WD-40 on it...Still nothing, I've tried pliers
1971 GMC Sierra
1959 GMC 100
Old 04-29-2014, 08:20 PM   #17
OrrieG
OrrieG's Avatar
Here is another current thread on turn signals not working
http://67-72chevytrucks.com/vboard/s...d.php?t=626977
and here is a diagram of the inside working on the stock switch, look at the thread above for my commentary.
Old 04-29-2014, 08:33 PM   #18
lowrodderchev
yeah thanx SCHRUMGMC you gave me some of your wiring gremlins LOL
Old 04-29-2014, 09:28 PM   #19
SCHRUMGMC
SCHRUMGMC's Avatar
Tough **** LOW !!!!!! Lol
I have a guy sending me a Tranny cover here soon, so it'll be great to fill that hole in the floor
1971 GMC Sierra
1959 GMC 100
