Old 04-24-2014, 09:48 PM   #1
duckdude
leveling stance
what do I need to lower my 72 1/2 ton with leaf springs to the same height as my front end?
duckdude is offline   Reply With Quote
Old 04-24-2014, 10:20 PM   #2
k_n_browning
Re: leveling stance
10 or 12 bags of concrete.Flip the rear.or use a set of drop shakles
k_n_browning is offline   Reply With Quote
Old 04-25-2014, 07:42 AM   #3
hamjet
hamjet's Avatar
Re: leveling stance
Knock the springs apart and 'de'arch them. you can leave the main leaf in the truck, (the top leaf with the eyes in it) cut the center bolt, and hammer out the other leaves on an anvel or two pieces of rail, set them back in place, drop the truck and see if you dearched them enouph, if not, repeat. when you get it where you want it put in a new center bolt and u-bolts and you're good. Hope this helps....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 04-25-2014, 07:45 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: leveling stance
Or you could call Early Classic Enterprises and order a pair of their 2 inch drop shackles. They bolt on in just a few minutes with basic tools.
Old 04-25-2014, 07:40 PM   #5
duckdude
Re: leveling stance
thanks for the help guys
