Help with Cluster..
I have a question about my gauge cluster..
There is gunk around the 'generator' gauge. I'm sure its old stuff from the 60s but I don't know how to get rid of it or what to do with it.. Also there is nothing in the hot cold gauge anything to replace that with also? Thanks |
Re: Help with Cluster..
someone has plugged the light holes for the gen and oil and high beam with some kind of crap looks like the are no lenses in the hot/cold and gen holes I would look for another cluster...looks like the fuel gauge is screwed to
you might want to take a look at this one the cold lens might be missing and needle in spedo is off/missing http://www.ebay.com/itm/321384707128...84.m1436.l2649
I'd take the cluster out of the bezel and inspect the insides. They are pretty basic and straight forward. I'd bet you could easily clean that one up.
The holes that are filled are just for the lights to go into. That's a warning light unit, not gauges. If it were gauges....it'd be a lot more questionable if it'd clean up. The only gauge on that unit is the fuel gauge and it looks ok from the pics. You'll see a couple of screws that hold the cluster to the bezel and lens assembly. If you remove those, the cluster housing will come off. You can easily see the screws to remove the speedo and two side pods. Be carefull with the fuel gauge....water will take the writing off. The metal housing which has the holes covered up can then be cleaned and resprayed if you want. I'm betting its fine underneath. Also looks to be a 63 cluster which will work in the 62. 60-62 warning light clusters had real temp gauges in them. 63 had a warning light system for the temp. Heres a pic for reference. I have seen them with both white or chrome paint on the lens cover.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-25-2014 at 08:14 AM. |
I did not know that the 60/62 had temp gauge not lights if his is a 62 he should get the correct cluster so it will match the wiring I would think
#7 | |
Well guys.. figured it out, I feel like such an idiot. I took it apart again and look more thorough into it. The blockages in the lights were actually dirt dobber nests.. I poked them out and they look clean. Also I found the lenses for the temp lights on my workbench...
Sorry for wasting everyone's time. |
#10 | |
Cluster King
![]() Join Date: Nov 2012
In case you ever need anything, I have a lot of parts for these clusters in my inventory. Glad you got it sorted out. Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
LOL that makes a little more sense the lights were not plugged in and they said lets move in .....make sure you scrap the paint out of the light holes that use the steel socket's or they wont ground
Thanks for the tip!
#13 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
