Old 04-25-2014, 07:52 AM   #1
KyFarm
KyFarm's Avatar
Where to measure to make level
As you can see my truck sits with the back higher. It is a 4 x 4 so I would rather raise the front than drop the rear.
My questions are where do I measure to find out how much I need to raise it?
Is the distance from top of tire to wheel well supposed to be the same if level?
Thanks for any help.....
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 04-25-2014, 08:53 AM   #2
k_n_browning
Re: Where to measure to make level
Bed rails make sure you are on level pad.But after you level it stand back an look at it.Try not to look at the bed rails.Some times when you try to make it level It will look like it is running down hill backwards.
k_n_browning is offline   Reply With Quote
Old 04-25-2014, 12:43 PM   #3
71K20chevy
71K20chevy's Avatar
I would go at the bottom corner of front fender behind wheel well, and bottom corner on front of back wheel well. The 4x4's seem to have around 2" (give or take) of rake of them from the factory.
Nice looking truck!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 04-25-2014, 01:42 PM   #4
PGSigns
PGSigns's Avatar
Put it on a good flat surface that you can stand back and look at it. measure to the top of the front wheel. no put a floor jack under the front and raise it up a little till the body looks like you want as far as the angle goes. Now measure tot he top of the wheel again. Do the math and that is you number.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-26-2014, 08:29 AM   #5
KyFarm
KyFarm's Avatar
Nice looking truck!
Thanks for that.
2" does seem about right but I also have a BB in it and I'm betting that sunk the front down some.
I am hoping that a 2" front lift kit from tuff country or skyjacker will do the trick to make it level.
Old 05-10-2014, 08:59 PM   #6
desertnick69
desertnick69's Avatar
Heck from where the pic was taken it looks mighty fine to me. Very nice Shorty step.
desertnick69 is offline   Reply With Quote
Old 05-11-2014, 04:04 PM   #7
KyFarm
KyFarm's Avatar
thanks for that
Old 05-11-2014, 10:47 PM   #8
desertnick69
thanks for that
I had a 76 shorty 4X4 for 23 yrs. it sat the same way and i tried to level it, I did finally get it, I soon learned if I had a load in it or my trailer on behind it sat to far down in the rear so I put it back to the way it had been. It sat level with a load.
Old 05-17-2014, 12:35 AM   #9
familyfast64
familyfast64's Avatar
It would look good with another two up front I think. I like a higher front end when off roading too.
Live and let live
familyfast64 is offline   Reply With Quote
Old 05-17-2014, 04:13 PM   #10
PowerdbyChevy79
PowerdbyChevy79's Avatar
I always go off of the signal markers...its a good straight edge to measure off of...
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
