Homemade piston pin press
1 foot section of threaded rod, two coupling nuts (to get a LOT more thread engagement to reduce stripping threads), a 3" section of 1" threaded pipe with the threads ground down on one side to clear the rest of the piston, an old 5/8" socket hollowed out to slip over the 5/8 threaded rod, and some washers. Whole thing costs less than 10 bucks from Home Depot.
Tighten the nuts (either side) and the socket will push the pin into the hollow threaded pipe. When the pin comes free, the piston becomes all wobbly, so you know right when it happens. Super easy!!! I tried 1/2" threaded rod, but stripped it out after the first 3 pistons the other day. 5/8" just barely fit these pins, it will not fit through some pins though, so measure yours to be sure what you can use. If I had used hardened threaded rod or had better condition (clean) parts, it may have worked fine. NOTE: Miracle Grow will hopefully add 30 to 40 cubic inches...
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
Re: Homemade piston pin press
Looks like you're pushing against the piston. My store bought (OTC I think) piston press pushes against the connecting rod.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
is a fungineer
![]() Join Date: Jan 2009
If you were just removing junk pistons from rods, it wouldn't matter if you were pushing on the piston or not. Installing might be a different story.
Thanks for the idea bnoon, now I've got a project for this weekend!
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
Yes it pushes against the piston. I have only ever used it to remove old junk pistons, but I've never cracked one either and believe me, these ones were STUCK! They sat for 13-14 years and barely came out of the bores! I couldnt even rotate the engine and thought the whole engine was stuck with spun bearings or something. Turns out the pistons were pretty much glued in place LOL!
To install floating pins, you heat the small end of the rod with LP or MAPP gas, then quickly push the pin through the rod and piston. You litterally have seconds to work with it before it cools too much that it can get stuck halfway on. Search youtube for videos on that part.
#5 | |
Nice idea. Thanks for sharing. I do this sort of thing for a living. Don't think I'd press against new pistons, especially cast hypereutectic types which are more brittle.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() Last edited by GRX; 04-25-2014 at 01:26 PM. Reason: wait ... |
#6 | |
