04-25-2014, 12:24 PM | #1 |
Lowering Block & U bolt Question.....
I will be bagging my 70 C10 soon, and have a question about an existing lowering block and U bolt that are on the truck right now. Because I will have bags in the rear the U bolt that you see in the pic might be too long to reuse.. is that correct? And if so, will I need to get one closer to what was there originally. I should also mention, I will be putting a C-notch in it also. And If I decide to use the blocks will the bring it further to the ground, or is that too much? Any info. would be greatly appreciated.. Here are a few pics....
04-25-2014, 01:46 PM | #2 |
Re: Lowering Block & U bolt Question.....
Just leave them in. When you get the bags in look at the pinion angle and if it ends up being a little low have the 3 or 4 degrees cut off the top of the blocks.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-25-2014, 02:18 PM | #3 |
Agreed.... Leave them in.
04-25-2014, 02:27 PM | #4 |
way2lo2
leave them in, you'll be fine.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote. 216 481-5219 office 216 481-4240 fax 216 789-1647 mobile Way2Lo2@aol.com <----also my paypal http://www.hubgarage.com/mygarage/way2Lo2 |
04-25-2014, 04:33 PM | #5 |
Thank you guys... I'll post pics when all is said and done.....
