04-25-2014, 01:29 PM | #1 |
Dodge Dakota door seals are the real deal
I just installed some junk yard door seals for a first generation dakota and they work great. Good seal, good looking and simple, no glue mess.
04-25-2014, 02:06 PM | #2 |
Re: Dodge Dakota door seals are the real deal
Excellent find. Makes me want to hit the yards this weekend. .
04-25-2014, 02:38 PM | #3 |
GMCPauls sells that kind of door seal for our trucks, also.
///Relaxed Atmosphere |
04-25-2014, 03:36 PM | #4 |
Good to no I'm needing news ones
04-25-2014, 05:22 PM | #5 |
$26 from brothers for the correct ones
Nice discovery though |
04-25-2014, 05:26 PM | #6 |
looks like they fit good , I have heard they work great.
04-25-2014, 05:51 PM | #7 |
Moderator
Those require adhesive to install. The clip on style are far superior.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-25-2014, 05:59 PM | #8 |
I imagine it'd be great to pick up a used set but new rubber (regardless of design) makes it a pain to shut the door for a while while they break in. Man do they seal well though!
04-25-2014, 06:08 PM | #9 |
04-25-2014, 07:35 PM | #10 |
I have S10 door rubber which is nearly identical. No adhesive needed. A nice tight seal too...Just the way Walruses like 'em sorry, couldn't resist
Mike |
04-25-2014, 09:36 PM | #11 |
The Older Generation
I have been pushing the '87-'97 Dodge Dakota weatherstripping for years. Here is a thread from 2010 I posted in about them.... Plus many other threads over the years. I have used them in all of my vehicles. http://67-72chevytrucks.com/vboard/s...d.php?t=424746 LockDoc
04-28-2014, 01:30 PM | #12 | |
04-28-2014, 01:34 PM | #13 |
BigMike,
what year S10 works? seem to have a ton more S10s in the yards vs dakotas... thanks |
04-28-2014, 04:09 PM | #14 | |
I'm curious about the year of S10 also. Was there any change between the 2 generations? 82-93, 94-04?
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
04-29-2014, 05:11 AM | #15 |
82-93 S10. You can also grab a set out of a wrecking yard if you can find a good set.
I got them from a board member, GMCPaul http://www.gmcpauls.com/Pickup.htm. He doesn't call them S10 seals but they're the same. 9th line down, part #2660241. Here is a good thread on them as well. http://67-72chevytrucks.com/vboard/s...d.php?t=438649 I LOVE mine. Easy to install and have never fell off, or detached anywhere. Mike |
04-29-2014, 09:29 AM | #16 |
The profile of the S10 strip shown above is nearly identical to the Dakota ones I installed. The Dakota strips also have small perforation to expel trapped air as the door closes.
04-29-2014, 01:14 PM | #17 |
I ordered a set of the press in type one of the vendors had a 10% off special on last Christmas. I hope to put those in after I replace my fuel lines.
04-29-2014, 11:08 PM | #18 |
So after installing a new set of Dakota seals is it as much of a PITA to close the door as it is after installing a new set of the normal door seals on 67-72's?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
04-30-2014, 12:01 AM | #19 |
Read through the thread I linked above. Yes, any new seal will be hard to close until it breaks in, but the above link explains what you do to fix it.
04-30-2014, 08:31 AM | #20 |
Do the press on seals do much to eliminate some of the wind noise as compared to glue-ons?
04-30-2014, 09:32 PM | #21 | |
If you've replaced your seals with glue on and still get wind noise it might not be the rubber, your doors may not aligned correctly. Even if it looks lined up the front of the door may be adjusted to far out, allowing a gap between the door & rubber. I've fixed many a car with wind noise by adjusting the door (and then the fender to match) Mike |
05-12-2014, 05:44 PM | #22 | |
05-18-2014, 10:05 PM | #23 |
Here is a follow up. They ended up being about 2-3 inches too short.
Original next to the blazer weatherstrip. The doors close tight now!
06-17-2014, 12:53 PM | #24 |
Does anyone know what the stock S-10 or Dakota length is for these seals? Rock Auto has both as sets, but from the post above from Daner it sounds like the S-10 will be too short. The S-10 set from R/A is cheap at $29 and the Dakota set is about $41.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
06-17-2014, 03:57 PM | #25 |
Well, too short meaning I have a 2-3 inch gap between the ends. Maybe somebody else will chime in if they have similar or contrasting experiences.
