Old 04-25-2014, 07:07 PM   #1
Rollinsqrbdy
Rollinsqrbdy's Avatar
Unhappy 84 k10 keeps grinding when when I put in 4x4... Please help!!!
So every time I try and put it in either 4 hi or 4 lo it grinds terrible. I have it in neutral and even got my foot on brake pedal and still no change. I've done everything I know and can't figure it out. I'm bout ready to set the truck on fire Please help me. Thanks in advance for any info.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 04-25-2014, 07:12 PM   #2
Rollinsqrbdy
Re: 84 k10 keeps grinding when when I put in 4x4... Please help!!!
Can someone please move this to the 4x4 section. Thanks
New Mexico Member
Old 04-25-2014, 09:50 PM   #3
Gregs71
Countless times, I've had the transfer case grind moving between 4hi / 4low. Sometimes it does it, sometimes it doesn't. If its real bad I will turn the truck off, shift into the desired gear and restart the truck and move on. Just an idea...
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 04-26-2014, 03:37 PM   #4
sholl10
Sometimes it will split in easier if youre rolling a little instead of a complete stop
sholl10 is offline   Reply With Quote
Old 04-26-2014, 03:59 PM   #5
willett
Another Day, Another Dollar
willett's Avatar
Ditto to shutting the truck down in neut and making the shift. Happens to me
All the time
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 04-27-2014, 01:13 PM   #6
83GMCK2500
wow, never had an issue in my '83 since I installed Warn hubs on the front. With the hubs locked I can shift into 4H at a stop, rolling, or at speed; and 4L stopped, trans out of gear.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-27-2014, 07:27 PM   #7
Pano
Getting into 4L always grinds for me. Helps if being done on grass or other non hard top surface. I have shut the truck off as others have too.
Pano is offline   Reply With Quote
Old 04-28-2014, 03:05 PM   #8
Rollinsqrbdy
I can get it into 4lo turning the truck off but not hi. I also have to hold it in lo or it'll pop out
New Mexico Member
Old 04-28-2014, 04:02 PM   #9
crashz
crashz's Avatar
I've always shut the truck off going into 4low due to the grinding too.
Not high though. When shifting from 2 to 4hi, the case is not shifting through neutral, so it should not grind unless your rear wheels are spinning at a different rate than your fronts.
And if you have to hold 4 lo into place something is definately wrong. First order would be to check you linkages for sloppy-ness, bent linkages or out of adjustment. If you dropped the T case due to the lift or had the cab settle, that could change the linkage adjustment.
NP208? Mine had the shift forks wear through and I was stuck in neutral. I've heard they are a pain to do, so I put a low mileage replacement case in my 83(like 18 years ago).
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
