Stock tire height?
What was the stock tire height in inches for a 1970 C10? We're they the same height for all the years. I currently have some 28" tall tires on it.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Re: Stock tire height?
If your stock tires are 235/75-15 then the height is 28.88" The circumference is 90.72"
If you need other sizes see this site. >>> http://www.tacomaworld.com/forum/tir...ires=235-75r15 Just curious, What are you trying to determine? If it's for a speedo set up there's a special way you need to measure tire height. (NOT from ground to top)
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
G78/15B was the minimum stock tire in 70. Those run about 27.75".
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
It's for the speedo. How do you measure for the correct wheel diameter height other than the ground up?
because the tire "Squats" at the bottom you actually have two tire diameters. One is unloaded (Laying on it's side inflated) And the other is Loaded (With the weight of the truck sitting on it) Measure from the ground to the center of the wheel and times that by 2. This gives you the true running diameter of your tire.
Here's a good site to get all the info and parts you'll need.
http://www.transmissioncenter.net/sp...____va.htm#350
#7 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
#8 | |
Well I measured the squared tires. It came out doubling them to 26 1/2". Is that about right for stock height tires?
26.5 sounds about right. I'm not sure what you mean by "Squared tires" though.
You just need to measure up from the ground to the center point and then times that number by 2.
Lol. I meant squatted tires. Lol. Auto correct and no reading glasses on. It's a terrible thing. Lol. Thanks for the info on the tires. I was wondering what it should be. Since I'm close the speedo must be off in the tranny gearing for the cable.
Ah... I understand. I suffer from short arm syndrome also. lol
#13 |
The Niner
![]() Join Date: Nov 2010
Maybe I'm wrong, but I hafta disagree with you on this. When calculating speedo gears, you're not going by the height of the tire, but by the overall circumference. And whether the tire is loaded or unloaded, the circumference ain't gonna change.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#14 | |
This is from their website. "To determine your tires true diameter in relation to determining what speedometer gears you need, measure from the ground up to the center of the axle then multiply by two. The actual run out of the tire can be as much as 2 to 3 inches less than what the circumference of the tire measures. In effect your tire has two diameters."
#15 | |
![]() Join Date: Feb 2011
Agree with this..... |
#16 |
Read my post just above yours. This way of measuring the tires is from a very reputable speedometer shop. >>> http://www.transmissioncenter.net/sp...____va.htm#350
#17 |
Link would not connect to their site
#18 |
This one should work.
http://www.transmissioncenter.net/sp...____va.htm#350 This is from there site on how to measure tires to determine which gears you need. "To determine your tires true diameter in relation to determining what speedometer gears you need, measure from the ground up to the center of the axle then multiply by two. The actual run out of the tire can be as much as 2 to 3 inches less than what the circumference of the tire measures. In effect your tire has two diameters."
#19 |
It is probably easier and more accurate to just grab a GPS and see what the actual speed is compared to your speedo... if you are 10% off just change the speedo gear to get the number of teeth you need for to make it right, or just buy an adapter with the correct % correction. No need to measure tire height, unless you are buying new tires anyway and want to get back to stock height.
Look here for gears and ratio adapters: http://www.partshp.com/speedometer_gears.htm |
