Old 04-26-2014, 10:10 AM   #1
hogwild99
how to tell what year my hood is?
Is there a stamp or number to tell if my hood is a 68 or 67. My truck is a 68 but I am pretty sure the PO put 67 fenders on it. So I was wondering if the hood is a 67 as well.
hogwild99 is offline   Reply With Quote
Old 04-26-2014, 12:33 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: how to tell what year my hood is?
67 and 68 hoods are the same.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 04-26-2014, 02:39 PM   #3
hogwild99
Thank you for the response, sweet so I can get the correct 68 fenders and should match up fine?
Old 04-26-2014, 02:46 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
'67 and '68 hoods are the same sheetmetal parts. Most '68 hoods have that thin chrome strip 'gingerbread' trim, and have little holes for the attaching nuts in the leading edge.
Old 04-26-2014, 04:37 PM   #5
67chevy1series
67chevy1series's Avatar
The basic look of the 67 and 68 hood are the same some 68's had no trim there is one difference I have found between the hoods. They are the same in everyday except the flange/pinch weld at the back of the hood along the cowl area the 67 has the metal fold down and the back up and is spot welded until the edges just before it bends down to the fender with the body line. 68 has the metal fold down at a 90 degree angle and it stays like that and it's spot welded just like 69-72 hoods. The 68 hood seems like it would be a little better for the seal that screws with the cowl since the metal pointing down helps go into the seal and would probably (at least I think) would provide a better seal for water.
67chevy1series is offline   Reply With Quote
Old 04-28-2014, 08:59 AM   #6
hogwild99
I see I will have to check that out. I am in the process of trying to get it to start. It quit starting baout htree weeks ago and my neighbor called the city on me so I have 10 days to gt it running or get fined 100 bucks.
