![]() Join Date: Mar 2014
Backspacing for 15x6, 6 lug, front disc rear drum, stock height
Been doing some reading on backspacing - finding lots of confusing information (I think mostly because of folks large variety of setups). Thought I throw up my specifics and see if someone could assist.
I am trying to verify that a 15x6, 6 lug rim with 3.75 backspacing will fit my 69' with the disc conversion up front and drums in the back. It's a driver so matching all 4 corners for rotation is desired. Here are the rims i'm considering: http://www.summitracing.com/parts/wv...6334/overview/ Side note: Anyone ever done a special order through Wheel Vintiques? I am wanting to run white rallys - and I can't decide if I should special order through them or have my shop powdercoat them after the fact. |
Re: Backspacing for 15x6, 6 lug, front disc rear drum, stock height
ttt
member #16
![]() Join Date: Dec 1999
They are listed as pre 1971, which is prior to disc brakes. I would look for 1971 and later wheels.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Listed as "pre-'71" because they are 6-lug.
I built it
steel wheels ive seen usually have a good bit more room around them then aluminum. i have 15x8 with 3.75 aluminum on my 4x4 had had to grind the caliper bracket just a bit to clear them.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
