04-26-2014, 04:29 PM | #1 |
Brakes?
Hey guys looking for some pictures of disc brakes with 20" rims. I would like to purchase the 14" 6 piston willwood's but they are not cheap. Pro performance has a 12" willwood front and rear kit but I'm concerned they will look to small behind a 20" rim. Please list the rim size/brake rotor size. These are the rims I'm leaning towards with the brakes I want.
04-29-2014, 08:57 PM | #2 |
Old member
Re: Brakes?
20" Boss 338's with slotted drilled rotor with stock calipar.I want to go to a bigger calipar but nothing I have found will work on a stock spindal.
04-30-2014, 08:26 PM | #3 |
Re: Brakes?
Just purchased some items from way2lo2 aka Boris. I'm going to do c6 corvette grand sport brakes all the way around 14" up front and 13" out back with a parking brake. Can't wait to get going on it. The tear down will begin this weekend.
04-30-2014, 08:52 PM | #4 | |
Re: Brakes?
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
05-01-2014, 11:34 PM | #5 |
Re: Brakes?
Here's the ones u ordered from boris...I have same......front calipers not on in pic....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
05-01-2014, 11:43 PM | #6 |
Re: Brakes?
05-02-2014, 02:44 AM | #7 |
Re: Brakes?
14 inch front and rear bear 6 piston
05-02-2014, 09:47 AM | #8 | |
Re: Brakes?
05-02-2014, 08:25 PM | #9 |
Re: Brakes?
That last pic was rear .....only one i have right now....and 20's all around
05-03-2014, 09:27 AM | #10 | |
motor exploder
Re: Brakes?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
